ive got one that doesnt leak, so assuming good nick
will be coming out of the car in the next couple of months (once we take the dash out for the cage anyways) - how much of a hurry are u in for it?
Not in any rush at all - Have bypassed the heater core (Aircon = freezing now) and wont need it till April or whenever it starts getting cold
-D
