yeah i cant beleive im helping this guy out.. if he isnt driving with safety and courtesy i dont want him on the same road as me. but i do know what its like to get booked for something stupid (was on today tonight in the height of P PLATER hating season 2-3yrs ago) . It sucks ass.
seriously... you shouldnt have parked in a handicapped zone... and if your friends were only 2 min i wouldnt turn the car off.. just roll around the carpark. none of this stay with the car bs..
if you were with it and it was still on ie keys in (idiot) or turbo timer (also illegal- car should not be on when ignition turned off) cop may have told you off anyway
Edit: just showing how it wont stand in court anyway
Edited by jeffworld2
https://www.sau.com.au/forums/topic/143747-booked/page/2/#findComment-2683712
When the coppers say 'you'll get it in the mail' it's just a scare tactic. He was prolly laughing at you when you left.
HOT TIP: Leave your rear P plate on the parcel shelf like it fell down, when a copper's like wheres your P plate just look back and go 'ummmm it must of fell sorry I didnt realise'. I used to do it on my P's always worked and saved my being pulled over everyday.
Just as illegal as not driving with them at all.
A P-Plate must be clearly visible from 25metres away from the vehicle, when viewed from the front, or the rear, hence, why I can't put my green P in the rear window of the line. The window is too far tilted, especially with really dark tint (Legal tint)
As for the handicap thing. GET THE HELL OUT OF IT!
I'm sick and tired of going to the shops with my dad or what ever, and some soft cock P-plater is parked in the disabled spot and he can't use it (He is disabled!) Walk FFS! You are fully bodily abled!
Although, you will never get the fine in the mail at all.
Also, copper is technically never off duty. They're a civil servant IIRC, meaning, they're always on call.
https://www.sau.com.au/forums/topic/143747-booked/page/2/#findComment-2683845
The other day I parked at a mall and out of the probably 10,000 parking spots, maybe 5 were filled. I wrestled with my own mind but eventually bypassed the 5 disabled parking spots and hit the next available normal one. I am completely conditioned not to use them. I guess I don't need the recall stabilisation after all. :) (1984 reference for those who don't recognise it)
Also my Dad has the disabled sticker - with good reason - but sometimes he doesn't park there. He goes, "Oh there is probably someone more disabled than me." :)
https://www.sau.com.au/forums/topic/143747-booked/page/2/#findComment-2683866
Ha ha ha, at certain places my dad goes "I know I can park closer in a normal parking spot..."
But at certain places he uses them, other times he parks like normal.
https://www.sau.com.au/forums/topic/143747-booked/page/2/#findComment-2683881
Not always. I got a fine for a red light (which I never went through) from this fat troll cop not too long ago, they said "your fine will be in the mail" and guess what, it was. Assholes..
https://www.sau.com.au/forums/topic/143747-booked/page/2/#findComment-2691270
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
