are there impact sensors in the front of the car that set em off in an accident? what sorta front bar? maybe the wind at 220km/h has set it off somehow? maybe bending the bar in or something?
unlikely, but food for thought...
https://www.sau.com.au/forums/topic/143792-200sx-at-wsid/#findComment-2683507
