hi all,
in my r32, i have an aftermarket head unit (a jvc) so the two buttons on the dash head are not used. i'd like to connect them up to something, preferably the head unit (e.g. next track, previous track). is this possible??
here are the buttons i mean:
anyone have any ideas?
cheers,
sig
I wouldnt like your chances of getting it to work with your aftermarket radio like you want. there could be a way of doing it, but if you dont know electronics.. forget about it. You could use them for other uses, but they DO NOT handle high current through them, so be warned.
hmm, thanks chaps. i had the dash off yesterday for another issue and had a look at the connection - they share a plug with some other stuff i think (only looked at it briefly). i might have a hunt around and see what i can find out.
If you feel like it, you could quite easily hook it upto an aftermarket radio if you're handy with electronics.
Basically, if the radio has a remote control, you need to pull the remote apart, join some wires either side of the (Forward/Back) buttons so that they use switches on the dash.
Then, desolder the IR sender, and attach a long cable to it. Now, mount the IR sender up in the roof (Aimed at HU), hide the remote behind the dash and use the buttons away.
Obviously that's a "brief" over view, if you don't understand what to do once the remote isp ulled apart, this job isn't for you.
to switch the laptop on the radio button provides a momentary contact:
Basically find two points on the laptop (I used the docking port connection) that when shorted turn the laptop on. You could also solder wires to the laptop switch.
Run these two wires to the radio button switch. There should be a small black connector with 2 wires in it that is located behind the stereo slots - connect each wire to it - done
(Only the 'FM/AM' button works - I don't know how the 'tune' button is configured as yet)
(I've added more pics to my thread if you want to see more details on the install)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
