look like a piece of crap at first glance , but i went into it believing that rockstar games has never let me down yet... and i'm thrilled that they are living up to my expectations
i'm only about 10% in after playing for a good few hours over the weekend and i'm loving it so far
so yeah... its worth a look
Jimbo the great
https://www.sau.com.au/forums/topic/143988-canis-canem-edit/
if you think rockstar has never let you down, then cleary you have never played state of emergencey! man that was crap. so much hype, so little substance. :dry:
GTA series of course were killer. :)
I kind of liked the fact that it wasn't as huge as San Andreas, it didn't feel as overwhelming. You don't get the same thrill running from the cops in this as you did in the GTA games as if you hide for a little while your wanted level just drops as opposed to cops not resting until you're dead/you respray your car.
I've just finished the game with 90% complete. Thankfully once you've beat it you can keep playing to finish any missions that you've missed.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
