Ive notice in the last couple of hotter months, my car in traffic (heavy peak hour), when the temperatures in excess of 34, all of a sudden starts idling like a rotten piece of crap (heaps low idle like 400RPM) and taking off is rediculously doughy and sluggish. Then ill get home lift the hood check all the cooler pipes etc and they will be rediculously hot (as to be expected tho) and the heat shield will be "tinging" (cooling metal) to all buggery. Im just wondering if anyone else gets this, or what i should do to help this, or if turning the aircon on to get some additional airflow in will help ( i kno this helps in other cars as it switches on the aircon fan which draws cooler air in to the engine bay).
Cheers, David
https://www.sau.com.au/forums/topic/144094-hot-weather/
yeah my R34 doesn't like it much either .... but is fine as long as the car is moving. But still, I am going to take off the stock crank fan, and put in a heavy duty thermo fan. I am also going to rig up some sort of fan on the air conditioner radiator/compressor. When my car gets too hot while idling, the air conditioner actually turns off (hot air comes out) - I assume due to some over-temp safety mechanism. If I get out and pour some water on the radiator and air conditioner condenser, the air conditioner fires straight back up and works a treat for a while - the car seems to run better for a while too. I am also going to rig up a big water misted to spray the radiator for really hot days like I had on my S15.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2691826
cool, thanks Joel. Yeah I am thinking I will grab a JustJap alloy radiator, Davies Craig 20" thermo fan, bigger condenser fan, Davies Craig trans cooler (already have, just have to fit), and oil cooler (already have, just have to fit) then I will be all set for summer :)
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692304
I bought my 14" thermo from atracing on ebay.
From memory it was ~$80.
The fan wasn't a straight blade it was a curved blade.
Looks identical to this one.
http://cgi.ebay.com.au/HIGH-PERFORMANCE-14...1QQcmdZViewItem
What ever you get be sure its a curved blade fan, they push a lot more air and they are quiet.
Those justjap alloy rads are a bargain.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692402
dont forget coolant flush if you havent already, car will love you for it.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692661
put the heater on, that helps if u can put up with the extra heat in the cabin. it draws the heat from the cooling system so in theory it draws heat from the engine which should make it run slightly cooler.
with my car, heat naturally goes into side the cabin where the foot area is. and i press the recirculating air button so that it blocks it from coming in.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692667
what about the affects of different temp on boosting.
I'm only mentioning this because I have heard that thick/thinner air accompanied by the factor of its temp can potentially damage or over power a car that is not set up correctly or doesnt have the appropriate management systems in place.
Edited by SAZilla
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2693681
MMM, i would be worried bout anything else, but the idle was casuing the only real concern for me. Ive just set up a new CAI for the 32 hopefully to lower the intake temps marginally, guess we'll see. So no one has had the idle problem tho??!
And really the only solution is to get a bigger thermo fan or the like?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2694091
nightcrawler = used to have the pewter s15?
if so, this is andy, i had the R33 GTR (midnight blue), with Matt's 33 gts-t
i see u're still on the forum
we havent been on here for like 4yrs now..time just flew
howz the family?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695138
ahh how you doing mate? Yes it is me, and I still have the pewter S15 (want to buy it? lol) .... yep things are good - the usual : work hard, play hard - we have just returned from a week in Singapore, I spent a week in New Zealand skiing in August, and we spent a month in the USA last September. Work is good, but busy and no kids on the horizon just yet (thank goodness) .... how about yourself? Did you sell the GTR?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695152
had? what happened to it and what your cruising around in now?
i remember last seeing you (bout 3 yrs now @ bp) with a female and your car had twin pipes then you dissappeared.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695353
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
