Hey Guys,
Just chasing a pair of rear coilovers for the rear as my drivers side one has sprung a leak (well it pissed out all the fluid!!). I need a set for the time being while I get new parts sourced and fitted (it's my daily, so need to be able to drive it).
Make offers, I'd prefer ones that aren't leaking, but not too stressed if they are a bit as it's only meant for 2 weeks. I'll pay postage from anywhere in aust for overnight devliery as I need these asap (car feels totally shit as it's reliant on the spring only). For those wondering, no I'm not driving it, but I can only borrow the current car for a couple days.
Prefer somebody in Brisbane as I can pickup today.
Contact me via PM
Email: [email protected]
Phone: 0433621708
Cheers,
Ben J
https://www.sau.com.au/forums/topic/144112-r33-series-1-rear-suspension/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
