Got the car dyno today made 206rwkw with HKS 2530 FMIC and PFC. Now when I shift at high rpm (5000+) it will bog down with a cloud if black smoke on the gear change on every gear. I have done a map trace and checked Loads that the PFC used on the gear change and all is good. Second thing is I can not modulate the throttle to control and drift as the car jerks violently,eg if you boosted to 14psi and back off then on again, But it drives fine with good a/f mixtures. :D
surely you culd tune around a atmo bov with a pfc? atleast i hope so cause thats gona be the case soon for me.
Only if the tuner knows what he is doing, many don't.
Take it back to whoever tuned it and tell them the problem.
:nyaanyaa: cheers :happy:
or fit a real working blow off valve, as nissan had intended it.
a plumbback will work best for your car, turbocharger and ecu/tune.
i suspect this will be much cheaper and a far better solution than tuning around it.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
