the fcon sz pro i think it is, is pretty good, much like most of the hks ecu stuff but the problem is there are no local tuners, so you need to be in sydney and you only have like 1 or 2 tuners so they can charge you any price and give you any level of service they wish and you have no choice, you cant just walk away and go see someone else.
if there were lots of hks tuners in australia, sure go for it, but dont bother in australia, unless u have unlimited money, then if you do buy motec
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2699990
Not entirely true about the pricing... but I guess your concern Paul is very valid (per case application I guess)
I've had my car tuned twice now with the F-CON and both times the pricing has been extremely competitive when compared to elsewhere.
PM me if you want definite prices; think your mind might change afterwards.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2700006
They're one of the only places I know of that guarantees their tuning... if anything stuffs up they tune it back for you without question.
But true, the towing from interstate if a problem occured would be a nightmare.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2700086
"I've had my car tuned twice now with the F-CON and both times the pricing has been extremely competitive when compared to elsewhere"
were did you get this done what sort of tune did you get
i.e full tune or tidy up of a jap tune?
Ive been told that BD4's can not tune f-cons and they have a capboard full of ones they've removed from cars
I love to have been told the wrong info as my bosses gtr has one fitted and another 2 tough jap cars I know of have one fitted aswell
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2701668
Whoever has told you that BD4s cannot tune the F-CONs is full of it... they are the ONLY people in AUS who can and will tune the F-CONs.
You need to be a registered HKS Pro Dealer to even have the Power Writer software and BD4s is one of them.
Thomas Lee is their tuner and he knows his stuff... definitely worth giving him a call and talking to him. He'll give you his time as well unlike many other places who hurry to finish the calls.
What type of tune did I get? Well the F-CON V Pro came off a R34GTR so the tune was not compatible (not that I would have used it anyway) so I needed it tuned from nothing. Unlike the PFC there is no "base map" everything needs to be done from scratch.
My second tune was when I installed injectors etc etc... Most tuners would just modify their existing map - Tom did it from scratch again.
Both tunes lasted about 10hours each, and each time I've paid what most would expect to pay for a full PFC tune which I've seen done in even 1/3 of the time.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702573
Not going to start another debate about how good/bad F-CONs are but consider why most high HP cars from Japan use it over the PFC... also consider why a seemingly "piggyback" system would be preferred over a "standalone" ECU.
I was sceptical to start off with too... but after talking to Tom, seeing it done, and driving my car - I'm converted. Talk to silver r32gtst from here, he's running one too.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702577
I was previously using the fconv but am now using a power fc pro...
to me the flexibility of being able to choose my tuner is a big advantage...
i personally did not have a good experience with bd4s and would not go there again... although im sure other people are more than happy with thier service...
additional costs with the fcon are getting it wired in which has to be factored in as well
just some thoughts
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702591
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
