Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
G'day guys.
I have had heaps of people PM me to do another group buy, so ill do it for my fellow members.
(Some even Begged Me - won't mention any forum Logs names)
These are from Import Car Parts Plus in the USA.
GB: START 24/11/06 ENDS 20/12/06
What i found was some Arospeed USA RB20/25/26 Cam Gears.
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
These camgears are good for a RB20, RB25, RB26.
To keep the price down, I need to order 10 sets thats 20pcs in total. (Come only in Blue & Red Colour)
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you. Both ways are fully tracked so they won't go missing.
Express post cost an extra $10 nation wide.
Cost Price of the cam gears is $170 for the pair, or $85 for 1 pc.
So total cost for a pair will be $170 + $10 postage = $180
This gb will end in about a month or before if we can get the numbers.
Ordering To order a pair, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ Pairs $140
So who wants to start the list.
Don't miss out as this will probably be the last GB because its time consuming.
  • Replies 240
Posted Images
the stock cam gear is actually adjustable on the r33
you cant adjust it without removing it however
i tried adjustable exhaust side and it gained nothing
so you may just want to go for intake side only
:mad: I have always read that it's the other way around and that the IN makes no difference when adjusted.
ive got an exhaust sproket fitted on my, which was made by bass junky
to allow us to adjust the exhaust side with the stock cam gears
it made no different whatsoever, any changes and we lost power everywhere.
its basically a spacer that fits on the cam sproket so u can adjust it
Paul, I've heard that the inlet side is the adjustable side, and thats why people with RB25's only buy the exhaust side. Many people have reported midrange gains from retarding this Arospeed exhaust side cam gear. Yours may be an exception.
Anyone reading this dont be scared out of buying! there has been lots of positive feedback.
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
