Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
I'm not scared off by this at all I'm just getting a pair instead of the EX gear only. For the price they are might as well go for the pair anyway.
  • Replies 240
Posted Images
Hi Dom,
When you have time could you start a list so we can see how many there are being ordered so far?
My count is.. 20 gears
hey mate! send me a pm with banking details!
i bought these for my r33 not that long ago, excellent qaulity, now i have a GTR im keen to get another set! and yes i did get power increase out of the exhaust side wheel, infact 13rwkw more!
so to all the people wondering, exhaust is required to dial up some neagative/positive timing! i went for 2.5* negative! worked well. but talk ot your mechanic, i wouldnt recommend doing it yourself! hope we got more than 20 people! thanks r33kid... your a champ and veyr good to deal with!!!
I WOULD LIKE A BLUE SET FOR MY R32 GTR - RB26. THANKS...
Ok Current List
1) DivHunter * IN FOR A PAIR
2) Smooth * IN FOR A PAIR
3) Mike_ * IN FOR 1 GEAR
4) NV N01 * KEEN FOR 4 PAIRS
5) Nabil * IN FOR 1 GEAR
6) cln * IN FOR 1 GEAR
7) R33fourdoor * IN FOR 1 GEAR
8) Dspita * IN FOR 1 GEAR
9) Betz * IN FOR A PAIR
10)75coupe * IN FOR 1 GEAR
11)xRHETTx * IN FOR A PAIR
12)Giffo * IN FOR A PAIR
13)femno * IN FOR A PAIR
SO FAR WE HAVE 26 GEARS
Giffo my mate got 21rwk on 2psi less on his GTR. Because the gears gave him a precise tune.
c'mon people, get your orders in quick, these are great quality and excellent design! lightweight and they look good!
bets price on the net people. get in and grab a bargin!
cheers
Garth
Sorry its still $160 PER PAIR
READ THE POST.
26 Gears = 13 pairs
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ Pairs $140
This is down to $140 per pair, not far off the starting price of a single gear! :D
Ok Current List
5) Nabil * IN FOR A PAIR
14)StockyMcStock * IN FOR A PAIR
15)STRYKR 33 * IN FOR 1 GEAR
16)teazn_r33 * IN FOR A PAIR
SO FAR WE HAVE 32 GEARS = 16 PAIRS
Edited by r33kid
Ok Current List
can anyone please confirm if i need both for a r33 S2 96? i have been told i only need the exhaust cam gear. Thanks!!
Ok Current List
17)Darkboy *IN FOR A PAIR
18)Nismo_God *IN FOR A PAIR
19)Musky *IN FOR A PAIR
SO FAR WE HAVE 38 GEARS = 19 PAIRS
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
