does anyone know how to remove the rear seats?
Remove the 2 bolts at the front of the bottom section of the seat and it will come out .. revealing the 2 bolts at the bottom of the back section .. take these bolts out them pull forward a little at the bottom and force the seat up (sometimes can be a little difficult), the whole process should take 10 minutes.
As for the factory immoboliser ... doesn't have 1 standard to my knowledge
you will need aftermarket for the 3 point insurance requirements
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704158
If you need a immobilier try one of these......they stop anyone
But anyway,
Na the stock one isnt complient for what you need as it isnt 3 point and isnt all black wiring. i highly recommend getting a aftermarket one like a autowatch
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704211
Garry is right, they dont have one at all...
Mongoose also make a 3 point immobiliser with black wiring. M80 series.
The M80 would be my first choice for value...
I persoanlly run the M60S as it offeres battery backup and auto window up and is compatible with all turbo timers, which is perfect for turbo's.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2707997
M80 is a triple immobiliser, whereas the M60 is only a dual immobiliser, so the M80 would be the immobiliser of choice if your insurance company requires a triple (or 3 point) immobiliser system. The M80 series offers the features of the M60, plus more.
The M80 is compatible with Shannons Insurance requirements due to the triple protection of the immobiliser.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2708123
I would have to agree. The m80 is a good reliable immobiliser/alarm. go to autobarn at Slacks Ck. Not only do they know there shit, they also know skylines. i talked to one of the install dudes and he was able to say what i needed, what i didnt need, etc. Would recommend both the m80 for both insurance and piece of mind and Autobarn at Slacks Ck
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718234
whats the m80 worth and how much to fit?? anyone know?
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718526
Hi Guys,
M80 is the way to go! It has the three point immobliser, If you twist my arm I might be albe to through in a window lift module.
We have other alarms to but from my expeince mongoose are the best, If you want to be in contact with your car all the time, they even offer the SMS module.
If you have any Questions feel free to give us a call -07 54 9333 66
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718920
Well Matt the M60S set me back about $280 and it was a DIY job for an me, but then again im a qualified auto-elec... :pirate:
The reason I suggested the M60 in the first place was price... The M80 is superior hence why the model number is higher, but most insurance companies only require you to have 2 points protected and in this case money is Matt's issue so the M60 would be his best bet....
Seriouslly hit up Chris Rogers for a installed price as he will be your best bet being a club sponcer...
Better yet you can talk directlly to Sam and Chris this Sunday at the SCC... :kiss:
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2720324
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
