OK on the weekend of the 15th, 16th and 17th I am going to be in ipswich ripping apart my dash and replacing my heater core, those who are in the general area and want to stop by to help out or laugh or bring beer and laugh, please PM me and once i know where it actually is where we are going I'll let you know :laugh:
So far darrin has said he'd pitch in, and it will just be me and a mate, so any help will be greatly appreciated.
Brad, you mentioned some wierd, hard to get to screws, I cant seem to see any on the FAST pics I got below. I went through each FAST pic for the WGNC34 model and came up with these, am I missing anything?
OK so I will be at a workshop, so tools wont be a problem, but what other things should i have onhand, for obvious example, replacement coolant?
ANyone got any tips or tricks or any hints or secrets?
I know this is going to be a BIG involved job, so any help anyone could give would be great.
Thanks in advance,
Cy
https://www.sau.com.au/forums/topic/145059-replacing-heater-core/
Looks like a pretty similar job to the one I had to do on my R33
Will have to remove the steering wheel aswell to get the dash out. Will need a T50 tool to remove airbag from steering wheel, I have one if needed.
Will need to remove passenger airbag aswell
There is always some hidden bolts in behind vents etc.
Most modern cars are built all very similar.
Should be about a 4-5 hour job all up and a few beers :D
You reckon? Well I plan to arrive friday arvo/evening and make a start either friday night or saturday morning. It would be great if we got it all done in one day :D Because then we could have a go at rewiring my reverse light :P
Bugger. Ska I was hoping to meet you when you came down. I'm in for the chop on the 11th and wont bw out till 15th but figure i'll be a bit sick and sore. Hop it all goes well.
Dude, this took me about an hour and half just to remove and heaps of the dash and associated bits were already gone.
My suggestion is to take out the air con unit (this means a regas afterwards) and get at it from the side.
Snap the two plastic bits that hold it in and pull it out sideways. It should hold in place without them on installation.
I removed about 50 nuts and screws etc to get the bars out that cross under the dash. I got about 4cm movement but couldn't get them out.
Good luck.
  • 3 weeks later...
OK it's done, here is a few observations:
1. DONT EVER DO THIS IS FCUKING SUCKS DOGS BALLS!!!
2. Did I mention is freakin sucked?
3. It really sucked!
4. Everything that possibly could go wrong did.
5. Without the help and support of a lot of REALLY FCUKIN FANTASTIC people, I would not be here today.
Stan, yours fit beautifully, we have heat and aircon :D So nerr nerr to your having to regass the aircon :D:)
Other then that over the past 2-3 weeks I have had the privalege to have the help of some VERY VERY nice people:
Marc - Revhead - Without his help and use of a workshop i would never have been able to get this done, Marc and his whole family are wonderful people, even if his brother covered the rear passengers side of the car with bright green 2pac by accident :laugh:
Darrin- darrinspencer - Advise and rear camber bushes, which we ran out of time to put in.... stupid freakin heater core.......
Rob - qickstagea - Thanks heaps for your help installing the speakers, mate they rock! Maybe next time I'll remind you to turn your car off, :O 3hours worth of idling, man I have never heard of anyone forgetting to turn thier car off.... whoops :D
And to everyone else out there who has sent me their condolances, it really makes me proud to be a part of this wonderful bunch of people in the stagea section, and SAu.
I am going to go back to sleep now, ~19hours is just not enough after that freakin stressfull 4days :D
Yeah here is the diy:
1. spend 2 days unbolting and removing stuff
2. spend another 2 days trying to make it all fit back in...........
Yeah didnt really need it for the heat, just wanted to get it done so that it is one less thing for potential buyers to pick out.
On the upside I did fine out I have platinum spark plugs and the results of my compression test:
1 - 138
2 - 148
3 - 137
4 - 138
5 - 136
6 - 138
So all up not bad, I did the test about 5 times just to make sure i was right with number 2, but it always hit 148 for some reason, still nice to see the engine is nice and healthy :P
  • 8 months later...
OK
so my heater core has gone walkabouts
what model / part numbers need to be used to repalce it - ie what heater core from the 'skyline' family fits ?
otherwise its around $500 to purchase the stagea item from japan.
I bought this one (300zx) from here when i replaced my R33 core, just changed the hose connections over. FAST says that the Stagea core is same as the R33 core, 27140-0E010, the core seems to be universal on a few models, compare the picture with yours.
http://www.ttzed.com/products/products_det...=&do=detail
Why the F%#@ didnt Nissan make the core more accessible, instead of having to dismantle half the car, they usually go around the 8 yr mark, looking forward to killing 3 days of my life soon.
Edited by chook
OK
my R33 core just packed it in too. the 300zx core is a match as stated and it will be a whore of a job. lucky summer is coming and we get a few months to deliberate.
wanna fly over to sydney and help?
lol I'll hold your beer
hahahaha
me no kneel
as from tomorrow 7am (13/9) wont have any kneecaps =(
for me, the tune shop will be doing the work =(
................. next winter
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
