Hi,
I am having issues with my shifter/gearbox, my problem started on monday, apparrently sometimes i cannot get it into reverse *thats right REVERSE* all the other gears are fine, i have a short shifter currently installed on my car which was already on when i bought the car, i heard some negaative things about short shifters, but mine has been good since. I have had my gearbox fluids changed about 1 year ago. I will be draining and filling up the gearbox with some redline lightweight shockproof gear oil over the weekend hope this may solve the issue.
Any idea what could be the issue??
Cheers
Tommy
https://www.sau.com.au/forums/topic/145462-gearbox-issue/
Try put it into fourth gear and then pull the lever towards your body while in fourth and then slide into reverse while pulling towards your body still. Hope you can actually understand what i'm saying here. I have that problem in my car.
Edited by jantolis
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2719052
dude i feel your pain it feels like theres something bloking it. but i found if you slowley release the clutch abit u can get it in without crunching but if anyone knows why please pm me too coz its annoying. thanks
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2727411
I'm suprised to say, but this works real well, I dunno wants wrong, I fink my gearbox could be on its way!!
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2757640
Nah man, first is fine..
Funny thing tho, once i get reverse workin via 4 gear method as what was stated by jantolis, I drive for abit and when I put it in 5th gear it gets stuck. I then force in back into Neutral and after doing that I would loose my reverse gear...when i need to reverse I would have to re do the 4 gear method lol...
Gearbox or clutch... ?? :P
Its not the shifter and I put some redline shockproof oil into too...
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2757953
  • 3 weeks later...
there's some adjustment to be had in the clutch at the top of the pedal. Try screwing it a bit more so it drives the shaft thru the firewall a bit more. I had a similar problem ages ago after getting a new clutch. Adjusted and sorted the issue.
Michael
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2791389
Thanks man,
I'll give that a shot on the weekend.
I'll buy ya a drink if it works!! lol :)
Michael
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2795061
  • 1 month later...
It may be the reverse lockout spring. It's sorta common. Happened to me about a year ago and a few other guys since.
Try searching for "reverse lockout". I have a pic from FAST if you think it might help.
It's a cheap fix. You can slide the gearbox back a little and reach it from under the car - you don't need to drop the whole thing.
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-2948556
  • 2 months later...
Open (Shifter in 5th)
Engaged (Trying to go 5th-->Reverse)
Like Cowie said - if it's just the spring, You can get the assembly out the side of the box. If it's something more mangled, U might have to open up the top of where the shifter goes in.. . . .
There's 4 regular bolts, and 2 pain in the ass Torx-Head bolts to get the shifter cover off the top of the extension housing. If you unbolt the X-Member and drop the back of the gearbox a lil' with a jack, You might get access to it all. I'll take a pic tonight if I remember, while I'm putting My 'box back in.
Of course - You do know that there's no Synchro on Reverse, right?? ? ? If the dog-teeth are lined up wrong, U won't get it into Reverse. Putting it into 1st and driving forward a few millimetres generally sorts it out. - Cheers !
https://www.sau.com.au/forums/topic/145462-gearbox-issue/#findComment-3092583
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
