  • Replies 167
Hey all,
Im fairly new to the forums.
Im 16 and live in Whyalla. Currently sitting on my L's, but get my P's in march.
My parents bought me a black, R32 GTS, Type-M for my first car. Its stock except for rims, exhaust.
Alot of skylines here. Mostly R31 though lol.
Theres an awesome bayside blue r32 GTR here though. Very nice.
Edited by Whyallapunk
Hey all,
you are so lucky, especially that being your 1st car :D
i know where you live! hehe....
thats not meant to scare you..
i just go fishing down the end of your street. i drool at the sight of the gtr every time i drive past.
its exactly what i was going to buy until the one i was about to buy did a bottom end bearing...
thats not meant to scare you either.
Edited by Ryanrb25
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
