Hi everyone!
For those that might not be aware, the Skyline Charity Cruise for 2006 was held the Sunday just gone (3 Dec), with all proceeds going directly to the Starlight Foundation.
The money has been tallied up, and I'm very pleased to announce that, thanks to the generosity of people like yourselves, we have managed to raise a total of $1200! I'm sure the Starlight Foundation will put this to good use to help continue their invaluable work in the lives of seriously ill children and their families.
A special thanks to those who donated prizes for the day! These businesses all deserve your continued support (listed alphabetically):
Audio Express
Email: [email protected]
Services: Car audio and security - we come to you!
Ph: 0407 102 839
Fax: 07 3256 7741
Address: Mobile, workshop at 12 Fordham St, Wavell Heights Q 4012
Hi Power Racing
Email: (via website)
Services: Importing Japanese engines, parts and accessories
Ph: 07 3208 8814
Fax: 07 3208 4882
Address: Unit 4/17 Moss Street, Slacks Creek Q 4126
Koolas Graphics
Services: Vinyl graphics, for promotion or decoration
Ph: 0404 466 399 (Shane Arandale)
Northfield Moorooka
Services: Car audio and security, retail sales
Ph: 07 3892 2555
Fax: 07 3892 5573
Address: 7 Colebrook Avenue, Moorooka Q 4105
If you need audio/security, go-fast/tidy-up bits, or vinyl graphics/stickers for your car, call one of these businesses first :(
Once again, a sincere THANK YOU from the SAU Qld Exec team for helping to make SCC06 the biggest Skyline cruise EVER!
Kind regards
Marc Roberts
Skylines Australia Qld, Inc - President
https://www.sau.com.au/forums/topic/146149-scc06-1200-raised/
special thanks to the execs and anyone else roped into organise and run this thing, to coin a phrase:
"they were running around like blue-arsed flies, or chooks with heads cut off"
you guys did a load of work on this and it was the bestest day ever >_<
looks like you guys really know how to put things into practice!!
Well thats what the lotus car club said...
Maby we will Pimp out the exec team to them for extra funding... :happy:
BTW... We were never setting out to beat $2500 all we wanted was more than 104 cars and for everyone to have a good time... :laugh:
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
