Hey People :wave:
I thought I would put up a thread for the last SAU dinner of the year (as it hasnt been put up yet and running out of time)
So it will be a saturday night the 16th:
at 7pm
At Raquels Spanish Kitchen
98 Oxford St
Darlinghurst
http://www.raquelsspanishkitchen.com.au/Mambo/
We are doing Tapas menu which you can see in the link for the banquet it averages out at $12 a dish
We are looking at order atleast 3 dishes per person with the banquet and that fills you right up but you can only have one or two dishes complety up to you.
If you want good food then we will see you there!!!!
http://www.whereis.com/whereis/getMap.do?nref=getMap
I want us to go out with a BANG!!! :wave::wave::laugh: and have our drinking hats ON!!!!
IN
Jess and Andrew
DIF
Mike1987 -
Norm -
Jas25T -maybe
Adam
Liz
Amy -
doodz
Lizjane
Haysey :)
Smoky
Mars -maybe
Smasha
Acidkid
Tragic
Steve_gts4
N1GTR-maybe
Sh@un
Slide
lingerinsoul
Sl!m
russky-maybe
https://www.sau.com.au/forums/topic/146186-december-sau-dinner/
  • Replies 153
Posted Images
Hey People :wave:
So it will be a saturday night so lets put some suggestions down of were we would like to go???
I want us to go out with a BANG!!! :):):D
Im thinking City???
Jess :D
i think that sounds like an awesome idea!but where to go? there are so many different places to go
Sorry there will be a dinner in cronulla in January I promise or further :D
Why cant you come to the city dinner??? :)
A school night dinner in the city is hard from the gong
Even cronulla will be a stretch, I will try though!
What do you mean another! we had 1 like 3 months ago!
I live in the gong - anywhere north of helensburgh is city/sydney for me.
Wait a minute - I just read Saturday night!!!!!
I may be down, depending on the date and prior arrangements
>_<
How about the Bavarian Bier Cafe, there are three locations to choose from (two of which are in the city).
This or something similar would be great.
I seen that one :D
I like the look of the place but if we want to go somewere after are pubs/nightclub walking distance??? :D
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
