It really helps turn in, and stability on sweeping corners. I am not using the car for drifting, so Id like to continue to use it. Really comes down to driver preference, And Id like to see how far I can excel with the Hicas. Ive driven Non hicas cars my whole life, And Im liking the technology.
Please dont whore this thread. Lets keep discussions on track.
ahahah PUN!!!..
yeah fair enough but i dnt need a computer to enhance my driving skills.. oh wait.. quote F+F TD.
"i dnt need a computer to tell me about my throttle response" lol makes no sense
problem is its really delayed.well the hydraulic ones are.. i havent driven enough electronic ones on edge to differentiate between hydo and elec hicas. but m still not a fan. bit like attessa comes in a bit late in most cases.
most times the rear would wriggle mid corner as it kicked in late on the GTR and i would have to compensate with the wheel
  • 2 years later...
  • Replies 50
Time to Dig up an old thread.
As you may have read the issue was off and on randomly last year during this thread. since then has became a full time issue.
We been trying to solve it in another thread here
to no avail so far. The hicas lockbar is starting to look more and more promising. Although still If i can I would love to fix it.
Im after anyone that can lend me a Hicas computer from a R33 that I can test with.
Also if anyone knows , is there any difference between s1 & s2 or -Alsd models in reference to the hicas ecu itself.
installing a lockbar wont help the power steering issue
when I installed my lockbar I figured I didn't need the HICAS electronics at all so unplugged the HICAS ECU and the power steering disappeared - plugged back in and all back to normal
Dale, I'd say it's a fuse or the HICAS ECU itself
Hey warick, yea that thought did occur to me, that when / even if unplugged or disabled, the solnoid in the Powersteering will still be shut off. therefore not solving the ps issue.
Ive checked all the Hicas fuses (reading from the Panel Scematics) and the fuses are fine, is there a way to over-ride the Solnoid disabling the power steering?
With my 33 gtr it had the bum wiggle thing intermittently occuring when driving along. i had an idea it was the hicas system so i removed it and replaced with a lock bar recently. i have power steering still, but the hicas ecu is still in the rear under the parcelshelf although i havent checked all the fuses in the rear etc. im also running a vipec aftermarket ecu aswell with no afm's. i still seem to be having a problem with steering wheel seeming to hydraulically or electrically steering itself suddenly left then right, it sort of feels like when a car is tracking to the potholes in the road but its not that. it still doing this with hicas removed.also it feels like the steering wheel is slightly to the left of centre when driving u put it straight then it heads back towards that again. i was wondering if it could be a power steering issue (i.e. air in the system) also i noticed that the car has a series 3 gtr wheel on it, would this have any affect, and how can i tell if the steering wheel sensor is playing up?
With my 33 gtr it had the bum wiggle thing intermittently occurring when driving along. i had an idea it was the hicas system so i removed it and replaced with a lock bar recently. i have power steering still, but the hicas ecu is still in the rear under the parcel shelf although i haven't checked all the fuses in the rear etc. im also running a vipec after market ecu as well with no afm's. i still seem to be having a problem with steering wheel seeming to hydraulically or electrically steering itself suddenly left then right, it sort of feels like when a car is tracking to the potholes in the road but its not that. it still doing this with hicas removed.also it feels like the steering wheel is slightly to the left of center when driving u put it straight then it heads back towards that again. i was wondering if it could be a power steering issue (i.e. air in the system) also i noticed that the car has a series 3 gtr wheel on it, would this have any affect, and how can i tell if the steering wheel sensor is playing up?
sounds like your front left control arm bushes are gone. like mine :blink:, hicas does not move ur steering wheel.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
