Got 2 head rest monitors (Chinese make)
Brand new and come with mounting brackets.
Come with remote controls and all that is needed to install.
paid $299ea
Asking $250 now just $150ea
located in sydney
can post anywhere in oz at buyers expense
willing to swap for pc or phone
Edited by DANSR33
https://www.sau.com.au/forums/topic/146308-7inch-head-rest-monitors/
any specs at all?
High resolution LCD screen
Adjustable Image brightness/colour and contrast
On screen menu display
Adjustable upper and lower visual angle
2 way video input, V1 and V2
Left and right angle adjustable
  • 3 months later...
  • 3 weeks later...
  • 1 month later...
what brand are they?
they are hard to sell because you can get a monitor on ebay for nothin thesedays... and it will be a piece of poo
people need to know brands so they can confirm retail prices.
I already quoted they have no brand name, just the model number...
thanks for letting me know why they arent selling... :cool:
