One Of Adelaide's Toughest Street S13s........over $30k Spent.....
For sale: 1990 S13 Silvia
Asking Price: $16,000 firm
Kilometre's: 70,000 (exact km when I next see car)
Manual or Automatic transmission: Manual 5-speed
Engine Type: SR20DET 2.0 RED TOP
Complianced: Yes, this car is not a 15y/o import. It was fully complied.
Road Worth Certificate: N/A in South Australia
Registration: Yes, car has some registration still remaining on it.
Modifications:
This car is so extensively modified that some modifications may have been forgotten...
Body
Custom yellow paint with black roof. This is a one of a kind colour that I mixed personally. It is as bright as yellow can get.
Genuine Origin Stylish Front Bumper
Genuine Origin Stylish Side Skirts
Genuine Origin Stylish Rear Bar
20mm wider vented front guards
Custom FULL METAL 40mm wide body rear ($1700rrp)
15mm bonnet spacers fitted for cooling
Shaved boot with no wing
All badges and side moulds removed
All bodywork has been completed by none other than M&C Doyle Auto Refinishers, so it is premium quality.
Brakes
Full GT-R brake upgrade with 5-stud conversion
R32 GT-R discs and calipers all round
R32 GT-R drum handbrake setup (with custom brackets to mount lines etc)
Suspension
Adjustable rose jointed castor rods
Castor rod brace (supplied but not fitted)
Adjustable rose jointed rear camber arms
Adjustable rose jointed traction rods
Adjustable rose jointed rear toe arms
Metal cradle bushes
Solid gearbox mount (supplied but not fitted)
Solid steering shaft spacer
Top of the line fully adjustable Silk Road/Section RMA8 coilovers (adjustable king pin, camber, height, damper, body)
8 kg front springs
6 kg rear springs
27mm solid Whiteline S13 front swaybar
24mm solid Whiteline R32 GT-R rear swarbar
15mm hubcentric bolt on spacers on front
Engine
1994 SR20DET redtop
3 inch mandrel bent front/dump pipe
3 inch mandrel bent exhaust system
JunBL Racing Spiral dual outlet muffler with trumpet tips (Exhaust Technology special)
Genuine Hybrid intercooler
Genuine Hybrid intercooler piping kit
Bosch 040 fuel pump
Cold air intake with pod filter
Custom oil catch can (lies across fan shroud, but not currently hooked up)
Car has made 165rwkW on 1 bar boost. Easily spins 4th gear during drift.
Driveline
Extreme 5-puck button clutch
Cusco 1.5 way mechanical LSD
Interior
Car is fully stripped inside. All that remains are door trims and dash.
Car is registered as a two seater allowing legal roll cage to be fitted, and bucket seats.
Sparco Sprint full bucket seats (Driver AND passenger)
Sparco deep dish rally wheel
Sparco gearknob
4 point race harness (supplied but not fitted)
Spin turn handbrake button
Rolling Stock:
The car will be sold with a set of 17x9.5 +15 Koya Driftek’s fitted.
For an additional $1000 the Drifteks will be replaced by the Work Emotion CR-Kai’s as seen in the photos (17x9 +17 front, 18x9.5 +12 rear).
Other Notes:
This car is exceptionally well set up. It has been aligned many times by Scotty at AVS Suspension to find the perfect setup. It feels extremely stable and predictable at all speeds. Aussie and CRAB 86 can vouch for this. The car is more than competitive at any level with the right driver, be it Super Drift OR Drift Australia.
It has covered about 3000km (if that) in my hands since I purchased it over 3 years ago. The car has had 3 oil changes in that time using only premium products. The car is currently running Elf motor oil, and Martini Racing gearbox and diff oil. It has always been maintained to the highest standard. It will be sad to see her go.
Pictures:
Contact detail's: Benny Mack – 0410 278 984 or PM me on here.....
road registration?
sorry if i didnt see it in the essay description... :P
as in... did your N/A mean "is not available"... or "not applicable" for RWC?
Edited by SAZilla
We don't have roadworthy certificates in South Australia. The car has full SA rego, which is all you need to take it interstate and transfer it etc. This car can be driven on the street which is rare of something this modified....i spent a lot of time clearing a defect I had on it so people could enjoy it more.
Thanks for the support guys. The car is still for sale if anyone is looking for a pre built drift car that has had hardly any drift done in it (G1 and 2 practice days). Everything is still fresh and car drives beautifully.
Yeah motor itself is internally standard with most standard bolt on bits etc.
Was never necessary to make more power than it does. That is for the next owner to work on......$2k and it'd make 220rwkW reliably....i just can't justify doing it to sell the car, hence the cheap price.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
