I have just bought a new catback so mine is up for sale
It's a Kakimoto with oval stainless rear muffler and an oval resenator. It is straight through design and flows really well. Infact it made 212rwkw on my RB20. (actually more like 230rwkw but i only have a sheet to proove it that says 212rwkw.
It is very quiet with a nice deep note and has jap writing on the stainless site bit.
it is 2.75" diameter but as stated it wil flow easily enough for 200rwkw. there is a dent in the mid resinator but it does not affect performance at all and you cant see it unless you are under the car :D these cost $790 new so $250 is a bargin. I even have dump and front pipe if needed...
I will add photos and dyno printout if needed tomorrow night. It is located in canberra but I can ship it anywhere at buyers cost.
https://www.sau.com.au/forums/topic/146378-r32-kakimoto-catback-250/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
