Do You Live Near Valley View And Have A R31 Or Kno Any One That Does?
Hey,
I was just wondering if anyone knew or owns a R31 skyline and lives in a house near Valley View high school? Its white with a black bonnet and they have been doing it up for ages. Have been dying to have a look at it for lik ever! Anyone kno of this place or are they a mate of urs? There is a 180sx at the same house and often there is a tiger micra commadore parked there. anyone help?
Yeh he bought it off of Myles and i belive his old boy did some of the body work on it! Adam swapped it to the new owners for a 4door turbo i also believe!
lol i might jus knock on the door n say hi i guess!
im sure he wont bite :P skyline drivers are very friendly and 9times out of 10 will stop what where doing for a quick chat about cars ... unless its footy season or crickets on
im sure he wont bite ;) skyline drivers are very friendly and 9times out of 10 will stop what where doing for a quick chat about cars ... unless its footy season or crickets on
lol :P
lol and how are you liking the FRONT WHEEL DRIVE ? :P
It is kinda torquey and loves to be pushed. the handling is great and its a very smooth car... you feel like your in a cacoon when @ 180km/h. It can get to melbourne on a full tank of petrol i reckon, only downside is that tyre changes are mandatory every 12-15,000 kms. had it for 12,000 kms and needed a new set of rims cause the insides where worn to the metal (mitsus camber on the 380s for handling doesnt promote rubber longegivity you could say). This could aslo be the occasional cruise with my mates to mt. lofty. 1 VR Calais v8 beast (deceased last week), 1x Nissan Sil80 (since defected), and 1 380GT. i could keep up with the nissan around the corners almost, but couldnt keep up with the v8 or the sil80 down the line. (turbo and v8 beast)
Sounds about right! he had that 4 door for a while now he's driving an old suzuki swift i think haha
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
