Recommended Engineers That Will Pass Drastic Body Modification?
Done a bit of googling and came up with nothing.. I basically need an engineer in SEQ that will pass a bosozoku long nose conversion.. Please include contact deatils if possible. Help appreciated!
Edited by Drift_Limo
If it's been done properly and according to ADR then any certified modification engineer will approve it.
If it hasn't been done properly then it shouldn't be on the road so no-one will.
Not really.
No offence or anything man, but thoes pipes running around the front of the car look super-dodgy.
but then again ive never seen thoes cars before and I have no idea of whats legal.
Even if it does pass, if its deemed to be unroadworthy at a later state theres nothin you can do. Engineers wont pass dodgy-mods these days cause they loose there ability to trade and the fines huge.
legally It doesnt pass ADRs
Some ADR extracts
ADR 13/00
25 No lamp fitted to vehicle has visibility obstructed
26 Angles of visibility as per sample vehicle evidence
ADR 42/04
5 No dangerous projections
they are just 2 ADRs off the top of my head
Nah just the long nose conversion.. Car is already built and still in Japan. Looks like a no go at this stage, wich is a shame because this thing was phat :action-smiley-069:
Your right it is a no go because of the bonnet protruding past the bumper. If people need a mod plate legally pm me
cheers exnizmech
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
