hey guys,
Just fitted my universal hks ssqv onto an adaptor that I got made up for me. Having many issues, car idles horrible, up and down like crazy from like 100 to 1000 rpm non stop, engine struggles and vibrates weird, while its doing that black smoke comes out of the exhaust, If i put my hand on the bov where it blows the air out the rev thing stabilizes but as soon as you drive again its doing it all again. I have blocked off the plumback pipe with a bottle cap, is that good enough? It had an O ring that i purchased from US which is too small and doesnt hold it tight so I have put a larger O ring to make it all sit firm yet under mild acceleration you can hear the bov wooshing(leaking air right?)
Since then I have out my stock bov back on and now my car has misfires on high rpm
Can anyone help me with this?
thanks heaps
https://www.sau.com.au/forums/topic/146571-hks-ssqv-stalling-problem/
yer i had the same problem...i just took it off and pout the stocker back on. thing is i noticed that the aftermarket bov didnt properly close when the butterfly was closed, like i revv the motor, it opens but closes slowly but not fully...im assuming its a faulty bov or i have a vaccum leak where I HAVE NO CLUE!!!
yea it seems to leak, but thing is i put the stocker back on and now my car misfores on high rpm when flat out, would it be coz the black smoke covered the plugs and they are no good? or is it coil packs which i doubt could be damaged by playing around with a bov.
2nd one I've seen play up... The valve c*cks sideways and gets jamed open = leak...
You should be able to close and you will hear it pop back into its place. It will work perfectly intil it gets jamed again.
Yeah as other said change plugs, because when the BOV is leaking its the same as intercooler pipe blown off and AFM reads all this Air coming in but its not actually getting into the engine... rich rich mixtures.
yeah i have a genuwine universal hks ssqv bov, im just gonna sell this one and buy a skyline specific hks ssqv which are not meant to have adjustment screw, is that right?
the rich mixtures must have stuffed my plugs, i'll replace the plugs on monday and reset my ecu and see how it goes.
Btw i had the car running with this dodgey bov for about 20 mins blowing black smoke while it was reving like crazy, would it damage my airflow meter by any chance?
wouldnt hurt to clean the afm anyway with some throttle body cleaner its not hard to do. im not sure about the car specific model having no adjustment screw, because all cars vary, like say you might have a standard car and it works fine on it and then you might have the same model car but with 300kw it want hold boost there or it will cause excess flutter/not open on the stanard car. i reckon the best bov you can get it the new greddy type rs it can be plumb back aswell. :P
how do you clean the airflow meter? pull it apart or something?
Why do you say the greddy type rs is the best?
what sound does it make? is it like a unique sound or the usual pccchhh! ?
Better yet, keep your original BOV and eliminate all your problems.
Personally id rather my car run properly then have a full sick phhhs phss whistle whistle where are the chicks? sound.
My car came with a turbo smart plum back bov but if i didnt i wouldnt have bothered spending that much to replace something that already works just fine.
thats true, but once you boost your car the stock bov doesnt hold boost and leak bad, so you have to have something aftermarket on a modded car
Well if you NEED to, go a plum back dude, i havnt had a problem with my bov at all, no idling issues or stalling.
If you have the standard ECU definately go plumb back.
yea thats my plan, either plumback the hks ssqv or get this greddy type RS and plumb it back
the greddy rs you can either plumb back or atmo, better than other bovs that do both.
you clean the afm with throttle body cleaner just spray it let it dry and then spray it again and it takes the dirt off pretty easy!
go to nengun for the greddy type rs they have cheap prices and vechile specific models.
Youll still be able to hear them if you plumb them back as well, so you can get the best of both worlds (that is if you like the noise of a bov)
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
