that ezyr34 is an r33! thats whats missing :D
Nothing gives that away :ermm:
Lol. I don't think thats whats missing.
ps. i can't put it in the R33 section, they'd kick me out :D
Edited by Owgasm
Haha, yeah, been looking for the front diffuser for months/years honestly!
The rear diffuser is a maybe if i can get one cheap.
I'm sure the problem is with most R34's that aren't V-Specs or missing the front diffuser is what makes it not look right.
One other way to tell its a R34 shell is its roof shape. I perfer it more than the R34 roof shape, its much more sleek and lower.
Hey all..some nice cars u all have!
Heres my old R34, sold her 6 months ago
Yeah, i remember this, seeing it at the Melb Autosalon earlier this year.
Saw it on the Dyno and must have been you with it.
my kit is bomex or bermex? i just picked it up 2weeks ago...
wtf r33 into a r34
is mine a fake r34? 1999 manaul r34 25gt non turbo >.<
how much is a turbo setup and is it easy to be done?
Edited by DeViLStaR
Yeah, thats what i ment about the roof shape ;)
Windows. geez, same thing lol.
Not as much as you'd think, but much cheaper than a R34.
Yeah, was based ona R33 GT-R V-Spec.
Also, the crease on the door, like basti said. For some reason you can see the crease clearly on it but when i see other R33's i can't see it :S
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
