Nice, big arse wing each to their own but sort of suits the car the way it has been kitted up.
Pitty ya didn't get the xenon headlights but.
it sort of suits the kit because its a full nismo kit lol.
but the wings a tad big for my tastes
Got bored this week, decided to detail the engine bay.
Before:
After:
I know it needs an air deflector, on my list of things to do along with making a proper air box, and polishing of the pipes.
But what'cha guys reckon?
Here are a few of mine.... Not to much done yet just dump pipe, highflow cat and tune.
Intercooler on order at the moment and more to come soon...
Hope you like... :P Sure you can guess which part is my FAV....
Edited by 99 GTT
can u detail my engine bay!!!!!!!!!!
puh leeezzzzzzzzzzzeee!
hahha.. yours already looks good tho cara.
awesome mate.. hey was it hard to get the mfd talking on it?
ummm yes well.... I swore alot...
I got the wiring digram from a guy called Purpleline on hkskylineclub and then well it was just a matter of splice and solder a few wires on the ecu, behind speedo and its all sweet.. Still have to fit the exhaust temp sensor and intake temp sensor but thought i would do that when the front mount goes in....
I would say the hardest part was getting the unit. lol :P
xenon lights are going back in this weekend
geez the halogens are shite!!
Very nice mate.... Clean looking paint and I like the wing....
cheers, noticed you got the same wing but not the rest of the kit? u put the wing on?
No Imported it like that. I have the Nismo front bar and the Wing just no side skirts, and the different rear bar not so deep. I was thinking of getting the skirts but i like the rear bar it still suits and blends to the rest of the kit. (not that i don't like the Nismo bar) so i thought id leave it.
Good idea to put the Xenons back in they are the best lights to drive to, it bugs me when i drive my work ute with normal lights lol....
u havent seen my engine bay upfront have u? cause it aint great thats for sure.but i have an idea for my engine cover tho :down: cant wait to see if i can get it done!!
My newly acquired R34 GTR VSpec II. Enjoy!
Far out man! No matter how many times i see that colour, it still looks hot.
I saw your ride last time at scs, when you had to have your bonnet up for judging. hey we still gotta do that double photo shoot.. maybe this year's scs hey?
ill probably have the new graphics on by then - might have to do it sooner lol le tme know at the moment im working most weekends but onyl for the next couple of weeks
and matty t helped my shine up my engine bay with tyre shine hahahaha
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
