Here's my precious baby that i been looking after for 4-5 months since i got it. Hope you guyz like it :P
Fully Dump
19 inch
Top Secret Front Bar
Custom 20 inch
20 inch
Full Ztuned Kit + 20 inch
Few bit and pieces of carbonfibre
Stef you are a hoe :) hahah
Lol...not as hoe as you yet :P. As for the wheels im using the 20 inch at the moment, the time attack and ztuned wheels is on the way but thinking going to sale them. So see how it goes.
Hey R-Spec
Front bar is a nismo one, i cut out all the brackets and crap that hold the number plate and opened up the mouth, i plastic welded pieces of plastic around the mouth to make it look genuine, with lots of plastic filling and sanding, once painted, bar looks genuine with a differnence
not a fan of them z-tune guards but thats just sex on pornographic rims! :down:
any more/bigger pics? what front bar is that?
CNBLOW nice car wingless ftw needs more dumpage!
I'm pretty sure that's the do-luck front bar on the white 34 with the black cf bonnet.
Hey R-Spec
OMG... please sell me your bumper! :down:
