Ok, thought i'd post a couple of my pics of my GTT R34 ,, yes it is a GTS-R badge.
Top Secret GTR front bar and Z-Tune Bonnet
Sorry pics not best it was raining at the time.
thanks for looking, just needs the top secret front diffuser lip
Very nice mate. Top secret bar is where its at!
doski, was your front bar meant for a GTR and it was modified? Or has someone gone and made a TS front bar that fits a GTT? You can see the nose piece is different to Forged's
Yeah my front bar is a GTR
which was remoulded and modded to fit a GTT, i dont have a seperate nose piece, it's all one piece.
cheers,
David
Pix of my car with my friend who done photo shoot for her portfolio.. didn't get any with just car as of yet but im sure you guys don't mind
Nice,if you don't mind me asking but what height is your wing? and where did you pick your wing up from ?
thanks,
Cheers
David
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
