Not a photo of my car (the outside is just too boring)... but it is a shot of the engine bay :(
Completed in September 2008.
[ Have a super duper intake pipe happening these days, yet to take photo - maybe later... ]
hey bakes, do you live around this part of m'wether or is it just where you took the photo... its on my running route.. awesome views from up there and its soooo nice and quiet... i dream of the day i can buy one of those houses, where the garage is up on the road and the house lower... i can just imagine working on a nice gtr, in my immaculate garage with big glass windows looking out over the beaches.
cheers
Linton
cheers
Linton
I live about 30 seconds drive from where I took that pic but not in that street. Cheers
Two more images of the rig after Saturday night's JDMST EOMM (October)
Photos courtesy of Vashcat on JDMST (http://jdmstyletuning.com)
Howie; car is running fine after the new plate - will know how much power 1.5 bar will hold on Wednesday :)
8110 car is looking sexy, same stan good work - like that black touch on the front bar, interested to see what it looks like with the bonnet down.
Bakes you make me sic youve got the car that probably 97.8% of us here want lol very nice mate! im planning to buy one when im 85 cant wait :ninja:
Stan.. i wish my car could just devour everything under your hood.. that's awesome dude.. seriously.
Eu jin - just checked out your blog again... that kit is a fantastic fit, + Japanese kits FTW.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
