  • 3 weeks later...
Looks great.
For some reason I didn't really like the colour coded middle and lower diffuser. But for the black GTR, it seems necessary.
I wish my fake could run R34 side skirts, i've got the z-tune skirt and pods, but will just run the pods :(
Will save the skirts my real :)
Thanks Simon. Do you mean because it's black, it doesn't need to be colour-coded? Or especially because it's black, it should be colour-coded?
Here's a pic of my old R34 which had colour coding all the way to the bottom. Car is also for sale as it happens - make me an (reasonable) offer! :)
Sorry for the confusion. Personal opinion, in the case of your black car, the lips should be colour coded to suit better.
Your last picture at that angle is hard to see the lips, but i'll go check it out in the for sale section :)
Full conversion (front/rear) was done many moons ago. (02/03 - r34 GTRs were over 80-90k plus, in saying that, it was done at much less than anyone could imagine [only paint was done by someone else])
Justification wasnt necessary, I believe the challenge was where it started.
niiiiiice. had a look at it again after i posted, would be good to get metal guards instead of fibreglass, but ah well. don't have the money to drop on it at the moment.. would love to though. S1 R33 with LM-GT3's, R34GTR VSpecII frontend? AWW YEAH
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
