Awesome pics Craig. It's surreal seeing so many 34 GTRs together like that! More pics of the N1?
Pics of Terry's N1 were taken with an iPhone and edited on the phone using Snapseed - definitely recommend this app.
i cehcked out the app - it will support android 4.0 ice cream sandwich soon which is what i have!
What the...?
I had to go and look that up, haha. But yeah it's a great little tool, costs a few bucks but worth it IMO
If any of you R34 Owners are after a bit of carbon "look/frp carbon overlay"
-> http://www.skylinesaustralia.com/forums/topic/390222-carbon-goods-for-r32r33r34/page__st__20__gopid__6221104#entry6221104
More buyers, cheaper for us all.
what size rims are on that white r34? they look like polished work meisters - beautiful!
Pretty sure they're 20's x 10.5 but not sure of the offset. I'm sure one of the WA guys knows....
That blue one is mint.
Do you have stand still pics of the white 34 with SLs... and more pics of the white 34 with meisters HOT...(front on if possible)
This is all I got, next time we catch up I'll get some more for you :thumbsup:
Which one is yours Craig?
Matt, I was driving at the time so no photos of mine! I've got a stocky MNP2 V-Spec, but it's nowhere near the pristine condition of the other cars!
Edit: actually first photo on previous page top right - it looks black though.
Edited by 32godzilla
Give yourself and your 34 some credit man! Any other pics of yours?
Very nice Terry - glad to see you enjoying the new car.
Us westerners caught up again today, here's some pics from the day, we had a total of 8 x 34 GTRs including 4 x Nurs, 1 x V-Spec N1 and the rest V-Specs!! I'm hoping to get 12 x 34 GTRs together for the next one :thumbsup:
Fantastic pics, thanks for sharing.
Yeah I did a little research myself and yes it does look very similar but I believe d34throw was a v-spec ii? Also the pics I saw showed red after market seats and gauges everywhere so unless Chris changed it back it's a different car. Huy and I will get the lowdown next time we see him. It certainly is a stunning example.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
