So what's next terry? I really enjoy driving my series 3 fozzer, such a well balanced and engineered car
The XT is a great balance between utility vehicle and performance eh Marko, so long as suspension 'n swaybar components are upgraded.
PM'd about prospective vehicle :)
Another pic from Camden last weekend for the masses...
I prefer the division in the front bar of BB and black 100%.
Not a fan of the same colour all the way down.
Just a bit too much blue for me.
Was it an option to have it all painted from factory?
yeah i'm the same....i dont like the all blue either. keeping a bit of black is good. dont think it was option from factory.
^^ Where's the best place to buy a genuine v-spec diffuser front and rear? or better to go aftermarket copy?
i saw a rear one a import monster when i was there getting my wheels 2 weeks ago. maybe ask aaron if he still has it. i didnt ask how much it was tho.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
