Many many thanks :)
I'll fill up this space today when I can about the VS2Nur and the N1 both featured together in...
a) Performance Garage #11 last month and
b) Performance Imports #161 also last month.
Matt and I dedicate these pics to...
Adrian Hodgson, Editor of Performance garage
Jason Round, Editor of Performance Imports and
Eric Tang Photographer
And perhaps I'll dedicate this post to Nick Nikolas and Terry Ashwood as they both share the story of the Black V-Spec II Nur coming to Aust and its later development.
Story as reported after Matt and I have had discussions with Terry Ashwood and Nick Nikolas:-
* The 2002 Nur was brought out to Australia in 2002. In other words, it was a new car. It was purchased by Terry Ashwood at a new price.
* The Nur still had plastic on the seats and door cards
* The odometer had about 200Kms on it
* Terry Ashwood's intent was to keep it pristine with ultra-low Kms.
* It could have feasibly been sent back to the Omori factory in Japan to become a Z-Tune
* That's the direction Terry wanted to take until he sold it to Nick Nikolas - and we respect that!
* At the time of sale, Terry had put on 19"x10.5" Nismo LMGT4 wheels and a Apex'i Power FC D-Jetro ECU
* Nick Nikolas took this Nur in a different direction - Matt and I respect that decision as well; otherwise Matt wouldn't have bought the car
* Nick used to own the JUN R32 GT-R which was doing 9s on street rubber at Cootamundra. That GT-R was an ADM. Nick has a few regrets about doing that to an ADM lol
* Nick did a few things (as you can see below) to the Nur that helped it do a 10.9sec run at Cootamundra. He only wanted to do that once and then preserve the car at low boost.
* Nick replaced the silver 19" LMGT4s with 20" Volk GTCs
* The Nur had a Big Brembo Brake Kit with floating discs and braided lines installed at over $20K
* Top end Ohlins Coilovers installed
* Ikeya Chassis Dampers front and rear
* C/F Prop Shaft from the UK
* The Nur also had Jun cams/gears, Nitto Oil pump, Large injectors, Nismo Fuel Reg, Larger Fuel pump (with an extra Nismo one spare), ARC Intake with Nismo piping installed
* Top end Motec ECU replaced the D-Jetro
* Nismo plenum was installed
* Nismo Titanium twin pipe exhaust
* Nismo MFD and Cluster installed
* The side skirts, rear pods are genuine Nismo
* The C/F VS2 bonnet was kept as a spare and replaced with a genuine Z-Tune with R-Tune intake kept as a spare
Piping is all there; but it's been turned off for ages.
* Matt has an ultimate street and track car which may make the track again one day soon so it can at least be tested around corners!
* Matt is the third owner, and yet this NSW car only made its first appearance at Legends Night in 2009, parked next to Rod Markland's GIO Chassis #4 GT-R
So three owners of this Nur there have been...
Three nicer guys you'd go a long way to meet :)
* Terry Ashwood
* Nick Nikolas
* Matt Tung-Yep
And perhaps I'll dedicate this post to Kristian Appelt and Todd O'Donnell as they both share the story of the V-Spec N1 coming to Aust and accidentally landing in my hands.
Story:- Many people may know that I've had a connection with Kristian and Todd for quite some time.
After all,...
Todd brought in my Bayside Blue V-Spec II with full Japanese history and barely 40,000Kms on odo. Both Kristian and Todd eyed off this one.
Todd instead, waited and waited for an N1. But so too was his mechanic back in Nara; and thus, it was going to be an arm-wrestle between friends at auction if no-one else bought it first.
Enter Kristian... He sits over auction houses in several countries and pores over specs all day long. And then he saw this...
Hey! And it didn't seem to be designated as an N1 either!
Kristian already had a V-Spec II N1, so knowing that Todd was looking for either a V-Spec N1 or a V-Spec II N1, contacted him.
And Todd said "YES!"
But Todd was stuck with a yard full of Corvette, Harley F400, Supra, 360, etc... that needed to be MOVED!!!
Time ran out for Todd and I had 36 hours to decide - and I'd only just completed a build on the VS2 under the advice of Steve-0, Piggaz and Yavuz at Unigroup Eng.
So here she is in my name - thanks to Kristian firstly (aka Iron Chef), and then Todd (aka JLM).
Not much different looking under bonnet to see if you removed all the Nismo items...
But just like the Nur above, it has "24U" stamped on the block on the passenger's side = N1 engine.
Still pretty though...
and it shifts - after you get past the lag, lol
  • Like 1
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
