I am looking at buying a Navara V6 and if the motor died I would fit a VG30t. Anybody done such a convertion? Any tips? What extras apart from motor are needed? Would I need turbo computer and AFM or just use an Apexi SAFC? Anybody know of some VG30t spares?
https://www.sau.com.au/forums/topic/146626-v6-vg30t/
T or TT?The vg30dett wont fit in most cars.even cars that came with a vg30 because of the the location of the turbos.They will usually hit on the chassis rails,very wide motor and a biatch to work on.Then again the navara might be wide enough to accomidate the turbos...The single turbo version is much easier but older.
https://www.sau.com.au/forums/topic/146626-v6-vg30t/#findComment-2738109
what you do is get the engine rebuilt and slightly modded, then with a turbo conversion with a decent sized turbo, do a LPG conversion and you should see 350rwhp no worries, with huge ammounts of torque...
my mate had this exact thing done to his z31 300zx (with the Navara engine)
you can find out heaps of info if you do a search, i can send u some links if u want..
https://www.sau.com.au/forums/topic/146626-v6-vg30t/#findComment-2741478
At an American site (Nissan Performance Magazine - NPM) there was an article called project Pathfinder . On the later bottom end they go it out to 3.5L I think plus headwork and a cam for better torque .
To each their own but I'd be careful giving purple hearts to a heavy vehicle , particularly one that has the gear reduction in low range that can break things . Low down stump pulling torque is what cross country vehicles like and in my experience their wide ratio gearboxes work better set up like this .
Petrol turbo engines are probably not ideally suited to that app .
I look for the article and post its title .
Cheers A .
https://www.sau.com.au/forums/topic/146626-v6-vg30t/#findComment-2741649
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
