What steps do you take to decrease lag after installing Front Mount Intercooler?
I have a Blitz LM Kit that im thinking of installing....
I have the following mods:
Turbotech BC set a 7 Psi
Full 3" S/S exhaust (Fujitsubo Cat Back)
Apexi Pod with heat Shield.
Would a tune be the simplest answer? What would need adjusting?
Mind you i dont have a Power FC or SAFC...
Thanks.
https://www.sau.com.au/forums/topic/146999-fmic-and-lag/
stock psi is 10 on a 32????
u sure?
i dont think thats right.....hmmm....google! lol
That is right and it's controlled by the wastegate actuator.
If you want less lag get a one or a combo of
Thinner FMIC - 60mm
3 inch split dump/front pipe
Metal Intake pipe
Supercharger
https://www.sau.com.au/forums/topic/146999-fmic-and-lag/#findComment-2744044
Second the split dump pipe, made a big difference for responsiveness on mine. Dunno about the supercharger or the metal intake though hehe, you might wana try some Cam gears as well
Stock r32's run 10 PSI, the gauge only goes to 7 because it's not measured in psi it's meased in mmhg or something, and that 7 = about 14 PSI
https://www.sau.com.au/forums/topic/146999-fmic-and-lag/#findComment-2744074
7 x100mmHg = 13.5psi
im confused. i swear my guage reaches the 700mmHg wen my car isnt boosted.
if you have a full zorst, FMIC and pod then your boost will spike to about 12psi, ~14 sounds a bit high :S
https://www.sau.com.au/forums/topic/146999-fmic-and-lag/#findComment-2744127
i have a pod, a full exhaust and a remapped ecu, and my defi guage reads 10psi.
:ninja: if u have a defi gauge definately trust that over your stock gauge, interesting that you dont seem to have any spike but that vcould be due to remap i guess.
https://www.sau.com.au/forums/topic/146999-fmic-and-lag/#findComment-2744133
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
