hmm..why has this turned into bashing posts ;)
Everybody has different opinions, and that is what the thread is for..constructive comment and some different opinions put forward... i was liking it till it got to bashing :)
Its a bit of a tough question to ask "what is the best all round turbo?" because one thing i have learned after reading all these sorts of threads over the months, is there probably isn't one! One that is good for in traffic, hitting at 2000rpm while giving you 250rwkw at the top end, good fuel economy (for those that don't realise more HP = more petrol) and whatever other "dream" people have. Can't have everything from a turbo,what you make up in one aspect of a turbo, you lose in another. It is all about compromise and what u intend to do with your skyline each day.
Stock turbo and some go fast bits is good enough to take most street cars to bed.. i mean the stock turbo is a very good unit as is compared to many other cars. I'm still trying to work out whether i really want to invest the money in something myself.. there is plenty of time. The more time you spend, the more knowledge you have and the better chance you have of getting something you are happy with.
For straight line: Of course there is no need for high boost..massive turbo, or anything as long as you have good traction to the ground and a good drivers foot. That accounts for a lot, and its a "free upgrade" most sane people should know that. Skylines are in a way the "thinking mans" car when it comes to dragging which is all good... There are the 9s Toranas and the like which are all ass no class - but there is no way you'd even get them out your driveway half the time.
  • Replies 55
Ive never seen a 9 sec gtst before tho
But your right, u of course have to figure out what u want from it, and b0neR has already done that and has asked the question.
Ive got a rehashed T3/T4 with the original R33 exhaust housing hiflowed and a .60 T4 Comp cover over a GT25 comp wheel... I got full boost by 3000 at mo but my exhaust wheel trim needs to be changed because its making the compressor wheel surge a bit because of the quick boost.
3500 full spool is the plan with the new wheel and 250rwkw at 1 bar ..
It hasnt made that much power yet but hopefully the macka special will come together...Its making the times so thats all that matters to me :D
do you count the japanese R33's in 9 second brackets....only they'r on street tyres....
Most gtst do 12s, only because thats almost the point where to get anymore horsepower, the budget doubles.....Hell, if i wanted a 10 second gtst, and had the money, yeah i'd go do it for the sake of it.... but i don't have $50K
Son of sydneykid
and btw, i dont actually have a car, im just a car nut and i love learning about anything and everythin, im only 15, the question was more so for a friend lookin to upgrade his gts-t and to broaden my outlook, but the response has been great anyway, thanx guyz.
Guest MFX_R33
Macka, how have you found your turbo, as i have been looking at doing a similar thing. I already have a highflowed turbo by Prescision Turbos here in Sydney (don't know the specs) but it is basically maxed out at 205rwkw at 17psi. I was looking at simply replacing the compressor housing and wheel, to see if I could push towards the 250rwkw mark at a similar (or lower) boost level. Keeping the same turbine set up I assume I shouldn't increase my boost threshold much.
Anybody have thoughts or experience with this?
Jeff.
Originally posted by benm
thoughts: ?
I'd love to try your ECU+Hiflowed Turbo on my car and see what it could do as im sure i could get more than 220rwkw from it.
What's he have? An EMS or something?
220 should be fine. It depends on what's been done to the turbo.
If they uprated wheel sizes it should be right. Apparently Brendan did a 235 but again - different people, different work done on the turbo.
Personally at $2,000+ I get the feeling high flowing is not my first choice.
But again calling around in Syd./Bris./Melb. - comparable flowing work can be done much cheaper.
Getting a scope on what work is done for what dollars would help.
205kW does sound a bit on the low side but... esp. w/ plenum
T.
Well the guy who did my flow work could not have been more personable.
He explained exactly what he was gonna do and he did the work quickly and too spec. and on budget.
Can't beat that esp. in an area where there's so much dodge.
I was given a max. psi loading on it - a 'never to exceed' warning but you're kidding yourself if you think you should run that pressure and on stock internals.
Now if you had $2,250 which was what GCG wanted, I'd be after a 2530 or something of that calibre but again I'm not exactly after huge kW nor am I after 12 sec. quarters.
T.
You gotta figure in the differences in dynos and the relativity of this.
For Example:
When my car was stock, on the Hills Dyno 140rwkw (DMX, non shootout mode) - On the Uni-group dyno 150 rwkw (DynoDynamics shootout mode) - That's a 7.1% difference.
The 235 rwkw I talk about is off the Hills Dyno - so if I take my 7.1% DD factor - then I am actually at 251 rwkw, which is prolly in line with expectations.
You also gotta look at the torque curve. I prefer lots of torque accross the whole rev range , make the car much more drivable. n other words, it's not all about peak rwkw. (unless you wanna be a HP Hero/Dyno King, nuthin wrong with that BYW, if that is yr thing)
At next opportunity I get, I wanna get a 1/4 mile time cause that is the real yardstick !
Cheers,
Hi guys, our R34GTT RB25DET has had its turbo GCG hi flowed. It makes 250 rwkw at 1.4 bar (which is 20 psi). It is not tuned for a single maximum horsepower number, it has a good spread of power as evidenced by its 12.4 for 1/4.
At around 420 bhp it's getting pretty close to the limit of the standard internals. It gets driven almost every day in Sydney traffic and has been for well over 12 months. Does 3 or 4 drag meetings per year and 4 or 5 circuit sessions. All this on Optimax, no octane boosters or special brews.
We could tomorrow turn the boost up to 1.5 bar (22 psi), stick some Elf Turbo Max in it and tune it for another 40 rwkw easily. But at close to 300 rwkw it wouldn't be as nice to drive, handle traffic easily, live on the circuit for lap after lap and be totally reliable. At 480 bhp it would way over what I consider a safe max for the RB25DET internals, particularly pistons.
So having said all that, the point is we have found on this engine and a number of others, the GCG hi flow does exactly what they say it will do (a bit better in fact) provides good all round performance (daily drive, drag and circuit) and best of all it bolts up to the standard stuff. So no expensive and sometimes unreliable fabrication.
The only thing that comes close to this spread of capability is the pair of HKS 2530's we have on the GTR, but they cost 5 times as much.
Hope that clarifies why we consider it to be the best "all round".
  • 1 month later...
in zoom's No 46 issue. I saw a section gives information about Toyota's turbo. In issue No.42 they have info about Nissan's turbo. Does anyone here got that issue and could post out the info about skyline r33 gtst turbo's info.
like Max Boost and Max rwkw?
thanx.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
