I'm wrecking a series 2 1997 R33 GTST
Most parts available.
* RB25DET motor with ECU/wiring/AFM etc 63,500k's ****SOLD****
* Automatic gearbox $700 now $500
* Brakes hubs,front rear $SOLD*****
* calipers $200 rear discs $100 pair
* Passenger Headlight only $300
* Grille ******SOLD*****
* Drivers door $200
* Door trims $150 each
* Seats $500 front & rear
* Front reinforcement bar ****SOLD***
* Rear reinforcement bar $150
* Fog lights pass only $150 each
* Front bar lower lip damaged, some damage to bar $50
* Rear 1/4 glass $100 each
* Roof lining $50
* Sunvisors $30 each
* Speed cluster $200
* dash parts from $10
* Boot lid (black in colour) $100
* Ignition barrell with keys & door/boot locks $200
* Radiator manual $150
* Condensor $80
* Auto diff centre $200
* Drive shafts $200
* Centre console $60 auto
* Tail lights $50 each
* Std struts with springs $100 pair
* Std 16in wheels $300 2 good tyres, 2 spilt from accident
* Power steering rack***SOLD****
* Control arms front & rear $100 each
* steering wheel airbag sold $100
* Passenger airbag in dash ****SOLD***
* Glovebox $50
* Gear shifter $50
* Handbrake cover $40
* Handbrake lever ****SOLD***
* ABS unit $250
* Booster & m/cyl $150
* Airbox & snorkel ****SOLD****
plus much more, let me know if something you require.
Car in sutherland shire, can send parts interstate COD.
call 0417295636
Edited by sav
  • Replies 55
Dude! Is that your own car? What happened??
If so, sorry to see your loss! =-[
Not sure if you're negotiable, but if so, this is what i'd like and what prices i'm looking to spend: (+shipping to Sydney)
$20 Boot lid carpet + clips
$20 Sunvisors (pair) only if in top condition.
~$40 Dash surround
$10 Inside door handle surrounds (if seperable and in vgc)
$10 Mirror sails (inside from mirror, if no holes)
$20 Top and bottom steering column surrounds +screws
do you have any engine parts? I am after a suction side pipe, its a metal pipe that runs out of the firewall on the passenger side to the compressor. It has a small greenish knob on it that is used to fill the aircon system. Please PM or call me if you do. 0413521692
hey ill take the driver side window control unti switch. should look like my pic below, and it will have a white box conected to it with leads and will have a computer chip in the white box, i need the white box thats attached to the black unit as well, if you have it please!!
Edited by seriesII
I am going to Just Jap on Saturday morning so I will be in the "shire".
Please PM me your address and contact details and I will call in and see you during the morning.
I am after a boot lid lining, drivers mirror and door trims.
~$40 Dash surround
sorry dont have boot lid carpet
sunvisors want at least $30 in good cond
dash surround I have 5 people after asking $50
door handle surrounds the rectangualr things $10
mirror sales (is it the triangualra peices if sono holes $10 each
surrounds sold already
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
