Guest Allen Petersen
I've done it a few times in the past and thaught it was a GTR speedo I used in RB25 missions but took one out of a spare to use it and no dice. Soo ya somehow this information got lost from all the drinking i've dont in the past year. If you guys hav a car I can get it from that helps or even a pt#. Thanks guys!!
Ohh ya its for RB25 trans. Need to ditch the sending unit for a cable speedo. Thanks
****kk dont worri about the different user name its still me. Just had a mess up*****
Alright now I took the speedo out my GTR box and placed it by my RB25 speedo sending unit and its a lil short. I thaught to just throw the GTR speedo in the trans anyhow tpo see if she worked but I spin th wheels in the air and the speedo soesnt spin??? Sooo Im thinking I got the wrong speedo. What shall I do???
I pretty much need a speedo with this gear on it. It is longer and larger in diamiter. Im sure you guys know what your looking at better than me. Im going to go cheak some other RB boxes to see if I can match something up but im running out of ideas??? :P HAH Thanks guys.
get a vl turbo sender. its cable.
I live in Canada. No VL here :). A part number would be great. I can get parts from Japan in about a week to Canada sooo a JP part would be best :) thanks man.
Nissan navara. I've done it it works, same with a few others. Go to the ceffy section. Have a look in the sticky 'which parts are interchangeable' thread. Scroll down to where my RB25 gearbox conversion thread is and away you go. Its got the part # etc there. You should be able to get it in canada no worrys I would have thought.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
