Well i went shopping for a new bed today, and guess what, the Stagea fitted in the boot, the slat bed (albeit in peices) matress, and my subs! Its suprising how much space the boot has.
Does anyone find for such a big car, the leg room for the back seats are small or is it just me?
https://www.sau.com.au/forums/topic/147472-i-love-my-stag/
Totally agree. Leg room in the back is not much. I have a baby seat in the back and it is hard loading the baby in - definately smaller than the wifes magna. Boot is a lot bigger. I think they stretched the boot too much into the rear cabin area if you know what i mean.
https://www.sau.com.au/forums/topic/147472-i-love-my-stag/#findComment-2752461
Yep, me too, but I dont think they could have moved the rear seating back any further without extending the wheel base - have a look underneath and you will see what I mean. The position of the subframe for the rear diff etc kind of precludes it because of the lack of forward floor space
https://www.sau.com.au/forums/topic/147472-i-love-my-stag/#findComment-2752575
It has small leg room because A: japanese people are small and B: it's based on the same chassis as the skyline/laurel models, and as such has similar legroom. the only difference in rear seat room between the stagea and an R33 coupe is the head room, you're not jammed up against the rear window in the stagea
https://www.sau.com.au/forums/topic/147472-i-love-my-stag/#findComment-2752631
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
