D....de..def...defected (ho Ho Merry Christmas)
  • Replies 55
Just driving back from seeing a doctor, copper turned onto the road i was on, then merged his way into behind me, and flashed his lights on.
Came to the car and picked the first thing that stood out which was "the car looks a little low"
10mm on the rear too low and 30mm too low on the front.
If he has to go over the pits, they will know
exactly. Im planning to go over once, so im returning the driveline and everything to stock as possible.
edit/ the cop actually commented on how clean the car was with no leaks, and bushes are all good...
Edited by Bl4cK32
aw man that sux i also would of though the RB25 gearbox would of been ok
but i guess you might know better
The 25t box would be ok but one needs to find a factory gearbox crossmember and mount that bolts up to the rb25 box + R32 combo.
Unsure if a GTR/GTS4 cross member will bolt up. Some have said the Auto crossmember bolts up.
Then there's the single piece tail shaft. :(
was actually along the road that goes down to hallet cove along the 80km/h section. had to pull into the hungry jacks car park.
Only if your car was an auto gtst will a std cross member bolt in to make it look origional.
Looks like i can do all the swapsies with Cubes :(
no circlework with the Nismo diff either cubes :(
Edited by Bl4cK32
Looks like i can do all the swapsies with Cubes ;)
Bugger that's right near where I live. Will have to keep an eye out for that d#@$ head.
I thought the rule was for the ride height to be legal the car only had to clear the ground by 10cm. Doesn't sound like you're anywhere near that low, though 30mm on the front would be down a bit I guess, but not rediculously so. Glad I haven't lowered mine.
I want a Madaz Grandma :(
Edited by JazzaR33
Jazza,
There's a few different measurements it needs to pass not to be considered too low.
1. The R32 GTST must be no lower than 360mm all round.
2. The lowest part of the car must have 100mm ground clearance.
3. Some measurement of the headlight to ground height.
Number 3 is ignored as some factory cars are released with a headlight level that is too low. Some honda's from memory.
So 1 & 2 are the ones to look out for.
Just to note... My stock suspensioned R32 GTST measures ~365mm all around.
So the 360mm measurement means you cannot run lowered suspension. I'm assuming they have a slightly lower height to allow for some suspension sag, possible differences in manufacturing and or a full tank of juice.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
