Hey Guys and Girls,
Thinking about taking up Slides offer on the coils but out of curiosity, did anybody feel a noticable difference after installing them? OK, I know if your coils are cracked, der !, there will be a difference. My coils are perfect though, so I would like to hear about better fuel economy or smoother, better power.Perhaps even 1.1mm gap without misfires.
Just curious :thumbsup:
https://www.sau.com.au/forums/topic/147724-splitfire-coils/
lol Jazza.. There you go with your question marks again. haha :thumbsup:
The datalogit forums suggest otherwise.
A few of the blokes on there with higher powered 500awkw+ GTR's have had ignition break down issues with the splitfires. They drop the genuine coils back in and the break down disappears.
However, it was suggested the cause of the ignition issue was the splitfires requiring a different ign dwell vs rpm time. Some of them were able to work around it, others just went with genuine.
I believe something similar was also mentioned on the UK Skyline forum.
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756807
Here's a post I dug up quickly on the datalogit forums.
Hi people. after doing a search for info on dwell settings with the
PFC I came up with almost a big fat zero.
At work we have a Bosch FSA Scope so I decided to do my own testing
after researching what I should be measuring on various helpful
internet sites.
Here are the initial results:
Vehicle > Skyline GTR with Splitfire Coils and Standard ignitor pack
and NGK iridium plugs gapped at 0.8mm.
Scope measuring ECU dwell signal to ignitor and an amps clamp around
number 1 coil negative measuring current ramp up time.
Suffers obvious misfire at over 17psi boost at 290RWKW hence my
research into this area
Suspect not running quite right at 15psi boost 270RWKW but can live
with it.
At idle held at 1000rpm:
PFC Dwell Setting Measured ramp time
Original 15 2.3ms
16 2.6ms
17 2.8ms
18 3.1ms
20 3.3ms
22 3.5ms
and so on.
The setup on my car fully saturates the coil at 2.3ms after which
the current ramp flatlines.
What happened next was very interesting.......
at 2000, 3000, 4000 and 8000 the dwell settings only allowed the
coil about 1.9 to 2 ms of charge time, obviously not enough with the
coil ramp up current still increasing as the coil fired.
I ended up with my 8000 rpm setting going from the original 86
giving 2ms up to 100 giving a 2.3ms and a fully charged coil.
YAY!!!!
As you can see the effect of the dwell setting is not a linear
increase across different rpm settings on the measured dwell time.
ie: each setting really needs to be set using the scope with your
specific application!!!!
So all those misfiring skylines out there, I wonder how many could
do with a DWELL TIME TUNE UP, assuming that they actually can as not
all would have PFC AND the FC Datalogit software. I believe the
hand controller offers no such adjustment is that right ... ??
So,
what does this mean in the real world of dyno testing and
drivibility? All I can say at the mo' is that the car felt much
sharper in the throttle response on the way home tonight, but it was
raining :laugh:
Dyno testing is scheduled for Friday so I will carry out some
careful testing at 15, 16 and 17psi breaks with full comparo's with
my past runs with original dwell settings and post them up.
For all I know it could be the cause of my last post re: the RPM
sawtooth effect over 6000rpm on my charts.
stay tuned :P
Mike
lol more reading in the same thread came across this.. maybe he has other issues. :thumbsup:
Further to the saw tooth pattern problem I described earlier I found some info on the EFI101 forum site regarding measurement of engine misfire by looking at the acel and decell events of the crankshaft sensor signal in relation cylinder compression and firing on late model EFI engines. Systems with multiple crank trigger points, say at least per cylinder or even more, can provide the ECU with enough info to detect an irregular acel/decel event due to a misfire and then log a code accordingly... very clever.
What I may be seeing with this sawtooth pattern over 6000rpm is in fact a misfire as the CAS speeds up then slows down irratically ( as stated earlier by a forum member here ) this reinforces the fact that my dwell time has been inadequate to fully charge my coils. Interestingly enough the car "feels" fine at 15psi but still shows the sawtooth pattern over 6000rpm yet at 17 psi it turns to custard big time.
Time will tell.....
Cheers,
Mike
and some one replied with..
What happens if you swap to standard coils ? I had a similar problem
with high RPM misfires at high boost. 20+ psi with Splitfire coils.
Swapped back to standard coils and it was fine out to 25+ psi .
I have talked to a few other people that had issues with the Splitfire
coils.
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756818
i think a lot of people confuse a CAS that is not reading properly with coilpacks going out (or both)
in my experience, if you put a known good set of coilpacks in a car (new splitfires included) you need to check the CAS output, chances are you will see at high rpm inconsistencies causing the misfire.
we have a snap-on scan tool that can connect to the cas and show the output. really helpful
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756890
I have stock coil packs that have been cleaned and coated with industrial silicone and NEVER had a single misfire while running 10psi and NGK irridiums gapped at 0.8mm... i was only getting 350kms to a tank and read that a larger gap would help economy... so i gapped them to 1mm and it began to splutter each time i gave it a hit... so back down to 0.8 without a miss!
Cheers
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757022
Cheers
its 16psi where they break down and give ppl the shitz...
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757154
Either way genuine coils are just as good, just 2x the price. :D
Pretty much summed it up in a a line :)
I used stock coils (RB25) for over 350rwkw.
You only get splitfires really when your kill your own. If stock ones were half affordable, you would use those instead :)
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757157
may be a bit out of topic here...but im sure i have a broken coilpack but i need help on how to diagnose which one is stuffed...coz i dont want to go and replace all 6
does using a ammeter/multimeter to check be of any help? if so...which pins do i connect it to?
Cheers
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757455
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
