Hey Guys and Girls,
Thinking about taking up Slides offer on the coils but out of curiosity, did anybody feel a noticable difference after installing them? OK, I know if your coils are cracked, der !, there will be a difference. My coils are perfect though, so I would like to hear about better fuel economy or smoother, better power.Perhaps even 1.1mm gap without misfires.
Just curious :thumbsup:
https://www.sau.com.au/forums/topic/147724-splitfire-coils/
lol Jazza.. There you go with your question marks again. haha :thumbsup:
The datalogit forums suggest otherwise.
A few of the blokes on there with higher powered 500awkw+ GTR's have had ignition break down issues with the splitfires. They drop the genuine coils back in and the break down disappears.
However, it was suggested the cause of the ignition issue was the splitfires requiring a different ign dwell vs rpm time. Some of them were able to work around it, others just went with genuine.
I believe something similar was also mentioned on the UK Skyline forum.
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756807
Here's a post I dug up quickly on the datalogit forums.
Hi people. after doing a search for info on dwell settings with the
PFC I came up with almost a big fat zero.
At work we have a Bosch FSA Scope so I decided to do my own testing
after researching what I should be measuring on various helpful
internet sites.
Here are the initial results:
Vehicle > Skyline GTR with Splitfire Coils and Standard ignitor pack
and NGK iridium plugs gapped at 0.8mm.
Scope measuring ECU dwell signal to ignitor and an amps clamp around
number 1 coil negative measuring current ramp up time.
Suffers obvious misfire at over 17psi boost at 290RWKW hence my
research into this area
Suspect not running quite right at 15psi boost 270RWKW but can live
with it.
At idle held at 1000rpm:
PFC Dwell Setting Measured ramp time
Original 15 2.3ms
16 2.6ms
17 2.8ms
18 3.1ms
20 3.3ms
22 3.5ms
and so on.
The setup on my car fully saturates the coil at 2.3ms after which
the current ramp flatlines.
What happened next was very interesting.......
at 2000, 3000, 4000 and 8000 the dwell settings only allowed the
coil about 1.9 to 2 ms of charge time, obviously not enough with the
coil ramp up current still increasing as the coil fired.
I ended up with my 8000 rpm setting going from the original 86
giving 2ms up to 100 giving a 2.3ms and a fully charged coil.
YAY!!!!
As you can see the effect of the dwell setting is not a linear
increase across different rpm settings on the measured dwell time.
ie: each setting really needs to be set using the scope with your
specific application!!!!
So all those misfiring skylines out there, I wonder how many could
do with a DWELL TIME TUNE UP, assuming that they actually can as not
all would have PFC AND the FC Datalogit software. I believe the
hand controller offers no such adjustment is that right ... ??
So,
what does this mean in the real world of dyno testing and
drivibility? All I can say at the mo' is that the car felt much
sharper in the throttle response on the way home tonight, but it was
raining :laugh:
Dyno testing is scheduled for Friday so I will carry out some
careful testing at 15, 16 and 17psi breaks with full comparo's with
my past runs with original dwell settings and post them up.
For all I know it could be the cause of my last post re: the RPM
sawtooth effect over 6000rpm on my charts.
stay tuned :P
Mike
lol more reading in the same thread came across this.. maybe he has other issues. :thumbsup:
Further to the saw tooth pattern problem I described earlier I found some info on the EFI101 forum site regarding measurement of engine misfire by looking at the acel and decell events of the crankshaft sensor signal in relation cylinder compression and firing on late model EFI engines. Systems with multiple crank trigger points, say at least per cylinder or even more, can provide the ECU with enough info to detect an irregular acel/decel event due to a misfire and then log a code accordingly... very clever.
What I may be seeing with this sawtooth pattern over 6000rpm is in fact a misfire as the CAS speeds up then slows down irratically ( as stated earlier by a forum member here ) this reinforces the fact that my dwell time has been inadequate to fully charge my coils. Interestingly enough the car "feels" fine at 15psi but still shows the sawtooth pattern over 6000rpm yet at 17 psi it turns to custard big time.
Time will tell.....
Cheers,
Mike
and some one replied with..
What happens if you swap to standard coils ? I had a similar problem
with high RPM misfires at high boost. 20+ psi with Splitfire coils.
Swapped back to standard coils and it was fine out to 25+ psi .
I have talked to a few other people that had issues with the Splitfire
coils.
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756818
i think a lot of people confuse a CAS that is not reading properly with coilpacks going out (or both)
in my experience, if you put a known good set of coilpacks in a car (new splitfires included) you need to check the CAS output, chances are you will see at high rpm inconsistencies causing the misfire.
we have a snap-on scan tool that can connect to the cas and show the output. really helpful
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2756890
I have stock coil packs that have been cleaned and coated with industrial silicone and NEVER had a single misfire while running 10psi and NGK irridiums gapped at 0.8mm... i was only getting 350kms to a tank and read that a larger gap would help economy... so i gapped them to 1mm and it began to splutter each time i gave it a hit... so back down to 0.8 without a miss!
Cheers
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757022
Cheers
its 16psi where they break down and give ppl the shitz...
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757154
Either way genuine coils are just as good, just 2x the price. :D
Pretty much summed it up in a a line :)
I used stock coils (RB25) for over 350rwkw.
You only get splitfires really when your kill your own. If stock ones were half affordable, you would use those instead :)
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757157
may be a bit out of topic here...but im sure i have a broken coilpack but i need help on how to diagnose which one is stuffed...coz i dont want to go and replace all 6
does using a ammeter/multimeter to check be of any help? if so...which pins do i connect it to?
Cheers
https://www.sau.com.au/forums/topic/147724-splitfire-coils/#findComment-2757455
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
