Hey all. I found out recently that my ecu had been modified while it was in japan (yeah and whos hasen't). They put a "Central 20, SPL Computer Brain" ecu chip in it. My questionis does any one know anything about these ecu's. I would like to get it reprogrammed but don't know where to go for this. I hear that these ecu's are not that common and not many tuners do these units. Is there a reason for this. What makes them so much harder to reprogram. I amm starting to consider changing it back to stock or getting a new ecu such as PFC.
https://www.sau.com.au/forums/topic/148056-modified-ecu/
i have a remapped ecu in my 33 and a non remapped ecu that was in the car when i got it.
not many people remap the r33 ecu as it uses different chips to the r32. there are a few places doing it, but i'm not sure who. i think there is a place in brisbane who do it, as my mate apparently had his r33 ecu done down there.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2763066
Na it hasn't got a daughter board in it. I opened it up and the square computer chip on the board has been replaced for this "central 20" ecu chip. The chip is in a holder and is removable. I hope to connect up my comp to the ecu and try out a few programs to see what i can get out of it. I will take a picture of the ecu tomorrow if i get time.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765208
I have an Central 20 ECU on mine, well about to, i have tested it, made hudge differance ofer stock, plus 14psi was no problem. My mate had it on his RB25DET powered VL and it made 230rwKws with same mods as mine with sheets to prove it.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765466
I have a few central 20 .roms
Mainly for RB20det. YOu will be running richer past 4000rpm and TP limit is changed to 255 thus getting rid of what people call boost cut.
Also quite often timing is also around 18 deg in most of the high load parts of the map.
Get it checked on a dyno :)
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765476
Yeah i ran the car on the dyno and only managed to get 157rwkw and it showed that it runs very rich the second it revs up. The chip inside it looks to not be one of those eproms that you wipe clean with a UV light and re-burn. Any one have any places i can call about getting something done with it. i will post up some pics of the dyno run and the ecu itself.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765496
i am mearly ready off the chart that was provided by the tuner form the car, i know the tuner, and the car had an r34 turbo on an 94 series r33 det motor. The motor was stock, FMIC etc etc, but that's what happended, I am yet to test it on my car, but i will let you know. Just what i know, i know that seams high, but that is what it did. It certainly made a big differance in my car when i had it in there for a test.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765723
after i had my remapped ecu on i borrowed a mates wideband o2 sensor and tested out my afr's. at around 3000rpm it goes up to 12.5 for about 500rpm then drops to 12 till about 5000rpm where it slowly drops down to 11.4 at redline. that was at 11psi as the boost controller was playing up and wouldn't let me go higher. cruise is about 14.5-14.7
when i get a chance i am going to test it at 14psi and see what the afrs are like.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2766842
Sounds to me like the dyno or tuner may have been pulling your c0ck :P
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2766865
Yeah I think something could be wrong with my oxy sensor. Here is my run on the dyno and as you can see the air fuel ratio jumps straight to 10. I am unsure if this is due to the ecu being modified or what.
dynoruntt3.th.jpg[/img]
Any one have any ideas on my crappy dyno run. :)
Edited by jrocket
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2767604
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
