Just heard on the Tv over here that Possum is being taken off life support...the injuries were worse than initially thought.
Thoughts to his family.
Messages to : http://www.possumpwrc.co.nz/ReadyUpdate/celebrate.asp
RIP. If there is a heaven, it will have a gravel road.
/me cries
G
http://onesport.nzoom.com/sport_detail/0,1...79-2-21,00.html
http://www.nzherald.co.nz/storydisplay.cfm...section=general
http://xtramsn.co.nz/news/0,,3882-2322501,00.html
-snip---
Bourne's Injures Worse Than Thought
28/04/2003 07:29 PM
IRN
New Zealand rally ace Possum Bourne was more severely injured in Good Friday's crash than was first thought.
His family made a special announcement at 7pm this evening.
The rally driver has been in a medically induced coma in Dunedin Hospital since April 18th.
Bourne was injured in a serious car crash when he was checking out the course for the Race to the Sky mountain climb near Wanaka.
Subaru spokesman John Coker says he suffered a severe brain injury at the initial incident, and doctors have managed his treatment very actively until now.
However, the full extent and severity of the injury has only become clear over the last weekend, when medical staff decreased ventilation support.
Mr Coker says Bourne's condition deteriorated and doctors had to put him back on full life support.
The family says his condition has been re-evaluated today, and a brain scan carried out.
They say that confirms the original injury was very severe.
The family says continuing full life support is no longer in the driver's best interests.
Bulletin supplied by IRN Limited Copyright 2001 IRN Limited. All copyright in this bulletin remains the property of IRN Limited. Terms and Conditions.
---snip---
https://www.sau.com.au/forums/topic/14813-possum/
  • Replies 44
Originally posted by GraemeWi
/me cries
/me joins Graeme :(
so so sad....I thought he would improve...and then this happens :)
"It was a very difficult decision for everyone, but in the end it is in the interests of Possum," said a close friend of the driver, Murray Brown.
"He hasn't been alone the whole time he's been in hospital and he certainly won't be now. We're all just numb. His chance of survival is virtually nil."
story here
I don't think there's any point in delaying the inevitable...
RIP Possum
https://www.sau.com.au/forums/topic/14813-possum/#findComment-301084
Possum clings to life
29 April 2003
UPDATED REPORT
New Zealand's finest rally driver, Possum Bourne, is clinging to life today as friends and family gather at his Dunedin bedside while his life support is gradually decreased.
Possum Bourne Motor Sport general manager Murray Brown told the Waikato Times today he was on his way to Dunedin Hospital and would remain there for "as long as it takes".
http://www.stuff.co.nz/stuff/0,2106,2437135a11,00.html
https://www.sau.com.au/forums/topic/14813-possum/#findComment-301852
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
