hey like the title says i have a turbs that im not quite sure what its from...
i have done searches on ns.com and google but it keeps getting me more confused..
i have been told my turbs is a rb25 or a small turbo off a vg30 twin turbs setup..
but i bought the turbo as a vg30 single turbo as it is to go on my silver top...
teh turbs reads NISSAN 45V1..
please ne help would be greatly appreciated...
and also is it suitable for my 20?
thanks in advance
https://www.sau.com.au/forums/topic/148416-unknown-turbs/
could be RB25 or VG30 single.
both have that marking on the compressor housing. does it have a nipple for a boost/cvacuum line?
if it does it is VG30det if not it is RB25.
Thanks
hey cheers but im not quite sure im sorta new to the whole turbo thing..
hopefully this pic link works and someone could give me a def answer... thanks
https://www.sau.com.au/forums/topic/148416-unknown-turbs/#findComment-2770737
That is 100% a VG30DET turbo as it has a straight outlet join and a nipple for the wastegate actuator.
If you are going to use it on an RB20 use the RB20 actuator and you will run 12psi.
Also If you are able to find a shagged RB25 turbo you can have the compressor wheel and housing from it fitted to this turbo and you will then have a bastardised nissan turbo with all the best bits!
https://www.sau.com.au/forums/topic/148416-unknown-turbs/#findComment-2770761
this bastardised nissan turbo u speak of... so could i do it myself?
would i just simply buy a rb25 turbs and put the compressor housing and comp wheel on my vg30 and presto i would have a mad WORKING turbo?
https://www.sau.com.au/forums/topic/148416-unknown-turbs/#findComment-2772485
Just get a turbo shop to swap it over and balance it, shouldnt be very xxx'y
https://www.sau.com.au/forums/topic/148416-unknown-turbs/#findComment-2774117
well that clears up my problem then, i guess i have a vg30 also :(. to dam laggy for my liking, would puttin the rb25 bits on the front realy clear it up? less lagg. id prefure a steel wheel. p.s is vg30det steel wheel front?
https://www.sau.com.au/forums/topic/148416-unknown-turbs/#findComment-2774179
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
