  • Replies 6k
Posted Images
Oh and duc, i remember one of the guys at trade school had an S13 silvia, with an ARC oil cooler which was the same size as the front grille, and fitted neatly in behind the front grille, if you could do something like that it would reduce the risk of it getting damaged underneath the car.
i read that deluxe is going to a drift practice at air. u keen on drifts, sam?
i like drift. yeah i went to the drift nats in march i think it was. really good to watch. my car isnt really suited to drift, so i probably wouldnt participate in drift practice.
its aint where i am. Why u so excited that its raining sam? u like to drive in the wet, have a nice cup of chocolate by the fire, snuggle up in bed?
i dunno. i just like the rain, i always have. i was born on a rainy day, maybe thats why?
i wouldnt mind going out to watch if im better. although its all ns.com boys, should be ok.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
