  • Replies 6k
Posted Images
thats true sam..
Honestly I would prefer to 32.. but thats cos im a fan of the 32 .. So it all depends on what you actually like. look at them both and think about what you would prefer to drive..
We have a 32 and 33 both gtst. So if there are major changes with the gtr variety beside the rb26 then i'd take the gtr33 but becuase its out of my price range atm im contemplating a gtr32 as then its at least has 4wd and a rb26.
so how much are you gonna sell your 33 for duc?
that's the other thing, its seems the market for imports particularly skylines are at an all time low atm. Its hard to say, how much u think its worth sam? Its one thing to say how much i want but another thing is how much the buyer is willing to pay. *sighs
20K neg? you could put more, but it would take a lot longer to sell
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
