  • Replies 6k
Posted Images
here's where i got em from, i got some for the numberplate lights too
http://www.skylinesaustralia.com/forums/sh...4+parker+lights
Thanks Sam, I just posted on the thread.. hope they fit R34.. coz I was complaining how dull the parkers looked compared to the HIDs
He says they fit all skylines, so i dont think you'll have any probs:) i couldnt believe the difference, i should have taken before and after pics
Do you know of pricings? Got a mate that wants his Cefiro painted in cherry red like my car! We have already painted boot and interior but he need outside and door jambs done!
I could get you a price, the only thing is it would be a bit of a pain having to travel to and from MB
accident in the hills? that reminds me, when we went on the hill cruise i noticed a cefiro on jacks on the side of the rest point in the hills near corkscrew - u remember the one im talking bout sam where i was going to stop but couldnt.
Nah couldn't have been him, no serious bingle just hit a couple of signs and up a kerb, pretty sure it wasn't near corkscrew.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
