  • Replies 6k
Posted Images
Yeh i'll be heading out bout lunch time, Gotta take mates car to Walkers in morning, Gettin a Phat cage put in his RA40 Celica!
i was thinking of getting a roll cage but three things are stopping me atm
1/can ppl see them from outside of the car - full or half cage. i dont want them too
2/ goes my rear seats have to be removed
3/ is it hard to install
btw is the celica track dedicated or street car?
Yeh gonna be a dedicated Club Car, So his cage is gonna be welded in. If you want a cage, get tint to stop people from seeing, and just get a bolt in cage so it's not so hard, as for the rear seats, well thats the only problem, but hey atleast it's not a 4 door!
im considering that deluxe
how much u pay also for rego and insurance if i can ask mate?
I bought the car for $500 came with 6 months rego, but you would only pay however much it is to rego a 4 banga and i don't have any insurance on it(don't care if i write it off), but i should get 3rd party for other people. Petrol wise, no worries, bout $30-35 to fill and lasts a good week and then some. Skyline would take prob double that if not more! and the way i figure it is i'm puting 1000's of km on Corolla and now only 100's on the 33.
Damn i put mine on the dyno straight after i bought it, and lucky that because it was running well too lean almost detinating, But i knew it hadn't been on dyno for a good couple or few years.
having said that though. ive had the car for well over 3yrs now and theres been no dramas.
Yeh thats cool then, If you've had it that long then all good. I bought my car off of a mate, he didn't drive it all that much so i knew it was all good on his behalf, but the guy that owned it before him took it to Tilbrooks, and i have a problem with that!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
