  • Replies 6k
Posted Images
nah sam, 1st time there if i remember correctly. something to do with the fact that since his ebc wasnt working properly the was allowed to drive off without paying a cent but will pay full amount when he get a tune with a working ebc. wierd.
nah, its still here. i cant get the work done until i can borrow my sisters car. shes on holidays atm. so once shes back at uni, i'll drop the skyline off and borrow her pulsar.
are you still in the process of gathering parts?
i drove it a few times. Gearbox is very funny in terms of shifting to say the least. But it has tidal waves of torque compared to the line. s2000 is a different story - it has an awesome gearbox. Shifting is go slick and fun in that car.
Bachelor of IT.
I'm in my 3rd year so yer exams suck. :(
Especially J2EE - Internet Computing.
I'm a fiddler. I only 'try' to improve upon the current cheap $100 tune I had.
I found that when changing gear or simply flattening it the map trace was dipping to load point 20 then once accelerating settling on load point 19 through the rev range.
This load 20 point was running ever so slightly too much timing as it was causing highish knock readings.
I reduced load point 20 by one degree and left load point 18-19 the way it was and knock went from 35 down to 17.
So.. I dialed in another degree in to load points 18-19 and found knock didn't rise.
That 1 degree makes it feel more lively, but only makes throttle control that little bit harder in second.
Basically through the mid range its now running 17degree's instead of its previous 16 and in some parts 15.
These new tyres don't hook up though. :)
I bought some Firenza ST-03's.
If I don't ease my foot in to it second axle tramps majorly. :D
My subframe bushes are screwed, first things first during the holidays, I'm going to fit some pineapples, hopefully it will stop the subframe from slopping about and help with traction a little.
If I still get too much movement, over the X-mas holidays I'm going to drop the subframe and fit a set of new subframe bushes from Noltec ($190 from Unique Autosports).
Maybe, a big MAYBE fit a S13 3.9:1 diff as to help the rb30 get that little more speed from each gear.
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
